fullmonte77 Posted July 19, 2012 Share Posted July 19, 2012 I'm purchasing an Eibach pro kit for my car.1" drop front .8" rear.Is there enough adjustment to get it aligned with these on or will I need an alignment kit? Link to comment Share on other sites More sharing options...
kongzilla Posted July 19, 2012 Share Posted July 19, 2012 You'll have enough room to align with what you currently have. Link to comment Share on other sites More sharing options...
fullmonte77 Posted July 19, 2012 Author Share Posted July 19, 2012 Thanks.I know on the Impreza I have the front has an adjustable strut bolt but the rear did not.I had to buy adjustable bolts for the rear.But I lowered it like an 1 1/2" so that may be why. Link to comment Share on other sites More sharing options...
kongzilla Posted July 19, 2012 Share Posted July 19, 2012 If I remember correctly. toe and camber can be adjusted for the front. only camber can be adjusted for the rear. Link to comment Share on other sites More sharing options...
Windy Road Posted July 20, 2012 Share Posted July 20, 2012 Correct only camber in the rear. The only way to adjust toe in the rear is to get adjustable rear control arms. Either 4boxparts, perrins (if they sell both arms) or the whitelines. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 20, 2012 Share Posted July 20, 2012 ^No, you can only adjust toe in the rear with the oem setup. Front has adjustable toe and camber. For camber in the rear you need the whiteline camber bushings, or adjustable links. Link to comment Share on other sites More sharing options...
fullmonte77 Posted July 20, 2012 Author Share Posted July 20, 2012 Thanks guys.I just want to know if there is enough adjustment to get it aligned with this set up. Link to comment Share on other sites More sharing options...
whitetiger Posted July 20, 2012 Share Posted July 20, 2012 only toe in the rear, guys. Link to comment Share on other sites More sharing options...
dan04103 Posted July 20, 2012 Share Posted July 20, 2012 And just a tip for the rear toe cam bolt. It most likely will be frozen when you go to adjust. I had to cut the nut off with a cut off wheel and install new hardware. About 27$ from the stealership. Good luck! Link to comment Share on other sites More sharing options...
