CDubbs Posted July 9, 2012 Share Posted July 9, 2012 Warning: Super ugly LV. I pulled the TMIC and looked for vac leaks. Found nothing obvious and reassembled with the same symptoms. Forgot to reset the ECU. Two LVs posted, one prior to the reset, and one 40 miles after. I have tried reading around and given the limited data, does this look like a post turbo boost leak? I have a paper gasket on the turbo side of my TMIC and waiting for payday to order a "proper" one. Any input is [as usual] greatly appreciated. First shot is pre-reset, second shot is post. Mods: 2005 LGT LTD 5EAT -Rebuilt EJ255 w/ Mahle 4032 -AVO TMIC -Invidia UP/Catted DP -Perrin inlet with Gray plastic test PCV connector thing and hose ziptied (retention, not zipped closed) behind the IM -Dyno tune -Replaced VF40 with VF46 -Speed holes Unmodded: Stock Fuel, paper filter, stock fueling / original injectors No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
iNVAR Posted July 9, 2012 Share Posted July 9, 2012 I don't believe an intake leak would cause maxed out negative trims like you're seeing all across the board... I'm taking a blind shot in the dark here, but leaky injector? Link to comment Share on other sites More sharing options...
CDubbs Posted July 9, 2012 Author Share Posted July 9, 2012 That's certainly a possibility. About how long would it take to pull all 4 for a weekend mechanic with a bad assortment of tools? Edit: search worked, claims 30-45 minutes for a swap. Never should have caved to the wife for a place with a one car garage and no basement. She wanted silly things like proximity to a grocery store and a "nice neighborhood"... No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
CDubbs Posted July 10, 2012 Author Share Posted July 10, 2012 Does anyone know a particular vendor that has a good turn around on injector cleaning services? Doing some nat'l guard stuff for about a week and would be great if I could get them in under 10 days. Shipping from Chicago. No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
Lardo420 Posted July 10, 2012 Share Posted July 10, 2012 I have a paper gasket on the turbo side of my TMIC and waiting for payday to order a "proper" one. Any input is [as usual] greatly appreciated. small block chevy thermostat gasket Link to comment Share on other sites More sharing options...
CDubbs Posted July 10, 2012 Author Share Posted July 10, 2012 small block chevy thermostat gasket Thanks Lardo. Gotta love the camry rear end. No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
fishbone Posted July 11, 2012 Share Posted July 11, 2012 The gasket you want is ... Mr. Gasket THERMOSTAT GASKET Part No. 738G You can find it at Autozone, Advance Auto Parts, etc. Link to comment Share on other sites More sharing options...
