mdzowner Posted July 4, 2012 Share Posted July 4, 2012 as title states. does anyone have any idea what might cause this or a possible fix? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 5, 2012 Share Posted July 5, 2012 Stop by a repair place and they can scan the codes and tell you what may be the problem. You might try a auto parts store first, as most will read the codes for free. Have you goggled this problem ? http://www.google.com/search?q=abs+light+on+no+cell+no+cruise&sourceid=ie7&rls=com.microsoft:en-us:IE-ContextMenu&ie=&oe=&safe=active 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mdzowner Posted July 5, 2012 Author Share Posted July 5, 2012 took it to autozone, co code. however google suggests its the abs speed sensor going bad. anyone else had to change this out? Link to comment Share on other sites More sharing options...
mwiener2 Posted July 5, 2012 Share Posted July 5, 2012 You're low on brake fluid My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
