stocklgt Posted July 10, 2012 Author Share Posted July 10, 2012 Awesome, that's the exact setup I am running. Looking forward to your results. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted July 10, 2012 Share Posted July 10, 2012 I ran into a few problems today...my maf got wet from the rain or gunked up from oil and caused a few issues that kept causing me to pull over. I also couldn't go very far since my handyman/plumber was fixing a water leak at my house. I did however make a mock scoop delete out of cardboard. With the minimal driving I did, I didn't see any real change in IAT. I did a lot of driving at ~50mph and it showed only 15* above ambiant but as soon as I had to sit at a light, IAT shot up to 20-25 above ambiant and stayed there. Gonna swing by lowes tomorrow and make a real block off and do more logging. I should know forsure on Wednesday if it works or not. I have a 20mile highway drive to work which should provide consistent airflow and IAT reading. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 8, 2012 Share Posted September 8, 2012 Any update on this? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted September 8, 2012 Share Posted September 8, 2012 I drove for over a week with the mock set up(work schedule sucks) and the IAT measured post intercooler wasn't any different with or without it. I have a feeling it has to do with the sensor sitting on a metal pipe and flange that heated up and stayed heated. Even though my pipe is gold reflect wrapped, it just heats up and stays that way. Once it hits a certain IAT/temp after sitting at a light, it rarely drops 2* below that temp. Or maybe the Ebay/Xo2 core is getting heated up by the radiator and turning into a heat sink. I have since gone back to draw through due to some blow through problems so I can't measure post IC anymore. I've been throwing around the idea of a FMIC and radiator mister though... Link to comment Share on other sites More sharing options...
adreyna Posted September 10, 2012 Share Posted September 10, 2012 Subscribed! Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted August 15, 2013 Share Posted August 15, 2013 A little update on this: With the car on the brink of running again, I found my old hood scoop splitter and gave it a look. The center section is held on by 3 tack welds that were easily broken off by prying with a flat blade screw driver. With the center section removed, a flat panel delete can be bolted on and the whole splitter assembly can be mounted back on the car. I have not made the panel but will do soon. I've attached a pic, the silver sections are where the center section was attached via tack welds. http://farm3.staticflickr.com/2876/9510800287_32e1b0a97c_z.jpg Link to comment Share on other sites More sharing options...
stocklgt Posted July 17, 2017 Author Share Posted July 17, 2017 bump this from the dead - my hood is faded and i think im just gonna go with a 2.5i hood from a jy instead of repainting this one. Ill do some testing once the car is rebuilt and keep everyone informed. Link to comment Share on other sites More sharing options...
