98 lgt
Current Mods:
Power Mode
Kenwood Headunit/Speakers
Foam in doors and under carpets/trunk
35% tint all the way around except on rear
Fart can (going to be replaced)
Ralitek RSB kit 22mm to 25mm
Tribeca FsB (22mm?) with Whiteline Endlinks
K&N Cone to Maf adapter/ intake piping from 95 Legacy L
Current (Plastidip on wheels, got sick of cleaning them)-
As car was purchased.
Tinted Blinkers:
Tinted rear window, rear lights, added fart can (removed way to dark):
The RUST started:
One advice to really improve your chances to stop rust: Remove that useless black factory molding. Easy to do. It won't hurt the appearance of your LGT. Inject oil or grease inside after removing the trunk panel. Otherwise your car looks clean.
Water leaks in your trunk. If it rains hard, mine will have a decent puddle there. I drill some holes and put in wire grommets to let the water out.
I'm a native of South Carolina. I am a dying breed.
