starionesir Posted June 26, 2012 Share Posted June 26, 2012 I have a set of evo 8 brembo calipers that I was going to install on my gsx but am going to sell the car and was looking to install them on my 06 legacy gt. I did see the fronts can be installed by drilling the spindle bigger to accept the bigger evo bolts but was unsure if I can use the stock gt rotor or have to go with a sti rotor. Also has anyone installed the evo rear calipers or do you need to go with the adapter thats used for the sti rear calipers. Thanks for any info. Link to comment Share on other sites More sharing options...
Windy Road Posted June 26, 2012 Share Posted June 26, 2012 Theres a Brembo FAQ on Nasioc.com with info about the Evo calipers. I suggest you look in there. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
starionesir Posted June 26, 2012 Author Share Posted June 26, 2012 I read about the fronts but nobody has really said anything about fitting the rears. Link to comment Share on other sites More sharing options...
No DRFT Posted June 26, 2012 Share Posted June 26, 2012 Guess you'll be the test dummy. Do it and let us know I have no control over drippie. Link to comment Share on other sites More sharing options...
SCHM1AN Posted June 26, 2012 Share Posted June 26, 2012 AFAIK the Evo Brembos and the STI Brembos are the exact same, save for the bigger bolt on the Evos, so you should be able to use the STI adapter brackets for the rear. Link to comment Share on other sites More sharing options...
starionesir Posted June 27, 2012 Author Share Posted June 27, 2012 Thats what I was wondering so then I would just have to drill out the bracket and retap it with the bigger bolts from the evo. I'll have to look into that. Thanks for the info. Link to comment Share on other sites More sharing options...
Heedz Posted June 27, 2012 Share Posted June 27, 2012 Yeah tap it out for the bigger bolts. Everything else is exactly the same. Get 04 STi rotors front and rear Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 27, 2012 Share Posted June 27, 2012 AFAIK the Evo Brembos and the STI Brembos are the exact same, save for the bigger bolt on the Evos, so you should be able to use the STI adapter brackets for the rear. That is obviously not true for the fronts (the EVO's have an external cross-over pipe, the STI's have an internal one). I'd bet it's somewhat more involved than just drilling different holes. It may require trying to source a rear bracket that has no holes, then taking the car to a machine/automotive shop and having them correctly drill and tap the holes to fit. And that's assuming the spacing of the rear calipers are the same. I remember a thread on RS25 where someone put EVO fronts on their car using Spec-B rotors. Personally, I'd suggest holding out and finding a set of STI Brembos. The prices are coming down some. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Heedz Posted June 27, 2012 Share Posted June 27, 2012 cross over pipe? Link to comment Share on other sites More sharing options...
01rs25 Posted June 27, 2012 Share Posted June 27, 2012 Gets fluid from the left side to the right. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 27, 2012 Share Posted June 27, 2012 Bingo. The internal crossover is part of what makes the Subaru brembos cost more. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
starionesir Posted June 27, 2012 Author Share Posted June 27, 2012 The reason I was not trying to go with the sti brembos was because I already have a set of evo 8 brembos that I was going to use on my talon but am selling that car so I was going to keep them to put them on the legacy. Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 27, 2012 Share Posted June 27, 2012 Sell the EVO calipers and buy STI ones. You'll have less headaches. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
starionesir Posted June 27, 2012 Author Share Posted June 27, 2012 The wife will kill me if I put any money into the car right now. So I'm trying to use what I have from the other car on this. To bad the evo 3 16g turbo I have for my talon won't fit the legacy. I think I'm going to take off my aem boost and uego gauges out of my talon as well and put them in the legacy. Link to comment Share on other sites More sharing options...
Windy Road Posted June 27, 2012 Share Posted June 27, 2012 Actually it will. Look into Moore Performance. They have a header and up pipe combo that you can bolt a evo style turbo too. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
starionesir Posted June 28, 2012 Author Share Posted June 28, 2012 My turbo is off a evo 3 though so I'm not sure if that setup would work. The evo 3 turbo is a direct bolt on for 1st gen turbo eclipse's and will work on 2nd gen one's with a j-pipe. The one on moores site looks like it is for a twin scroll newer style evo turbo. I will email them just to confirm it though. Thanks for letting me know about that company. Link to comment Share on other sites More sharing options...
Windy Road Posted June 28, 2012 Share Posted June 28, 2012 Ahhh I thought they were all the same. My bad, bit rusty with my dsm knowledge lol 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
starionesir Posted June 29, 2012 Author Share Posted June 29, 2012 No problem I appreciate giving me the info it was worth a shot. Link to comment Share on other sites More sharing options...
