DJM891 Posted June 26, 2012 Share Posted June 26, 2012 Well, I will start by saying this was my 2nd head gasket job on a Subaru, third over all. I got everything back together fine, or so it seemed, but the car refuses to start. Car turns over normally does not appear to be any interference Timing is correct, aligned on II marks as shown in Subaru literature There is spark as tested on wire There is fuel pressure to the intake manifold via the fuel lines Will not fire even with Starter Fluid, not even a pop. If there is spark, and you use starter fluid, would there not be at least a puff, backfire, something? Is there a possibility that hooking the fuel lines up reversed (i DID do this at first) could have damaged something in the FI system? And if so, would the starter fluid not make it at least do something? Just thought I would see what the experts thought, before I give up and replace the whole motor (has 160 K ran fairly well before this but pushed coolant out of radiator cap) I have searched extensively for a solution all over the web but nothing seems to speak to this issue, or I just cant figure out how to search for it. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 26, 2012 Share Posted June 26, 2012 try a compression test. all i can think is the timing is off by a tooth on more then one wheel. BNR18g on 93oct Link to comment Share on other sites More sharing options...
