nicenlow Posted June 26, 2012 Share Posted June 26, 2012 I recently installed a set of Tien H-Tech springs onto my 08 LGT with stock struts.(38k miles) After the install I drove the car for about 4-5 days with no problems then I noticed a puddle near the right rear tire which was fluid from my right rear strut. I then started noticing a clunking noise at slow speed over bumps. Strut was bad. I just replaced both rear struts with KYB replacements and drove the car for about 3-4 days and noticed a puddle at the left rear tire which is fluid form the NEW left rear strut. Has anyone had issues with stock struts and H-Tech springs? I chose these springs because of the minimal drop and what I assumed would be an easy upgrade to my car. Now Im battling struts leaking. Please chime in with any similar issues and possible resolutions. I have changed springs before on numerous other vehicles, even subarus, never had this happen. Help? Link to comment Share on other sites More sharing options...
goneskiian Posted June 26, 2012 Share Posted June 26, 2012 I highly doubt that it's the springs causing the issues with the struts. I think that's just coincidence. Link to comment Share on other sites More sharing options...
Heedz Posted June 26, 2012 Share Posted June 26, 2012 Coincidence, I had H-Techs on Monroe stock replacements that I bought off of someone here and put 40k and they put a good 20-25k IIRC, No issues whatsoever. Link to comment Share on other sites More sharing options...
nicenlow Posted June 26, 2012 Author Share Posted June 26, 2012 Thanks for the input. Im sure it was something I did or coincidence. I dont seem to have good luck with these types of things. Thanks Guys. Link to comment Share on other sites More sharing options...
FJuan Posted June 26, 2012 Share Posted June 26, 2012 I've been on H-Techs & Stock struts for over 60k miles now, no issues. Did you make sure the bump stop is in the right place? If there's no bump stop and you bottom out, then that could lead to a strut/shock failure. Check to make sure all the parts are in the right place. Also, check the mounting cap at the top and make sure there's no movement or cracks in it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
