wpgcima Posted June 23, 2012 Share Posted June 23, 2012 I have a 97 BG5 GTB twin turbo ej20r but when i bought it the shift linkage was as sloppy as a durty hookers vajiji ... if anyone has experience changing the shift knuckle and knows the part number for it for my car that would be shweeet! i know its a bitch to change but ima probably just pull the whole linkage out and change all the bushings too. just bought some COBB polyurithane bushings so those should help with the sloppy joes but if someone knows the part number for the knuckle that would be sweet! also if you know what you're talkin bout any advice would be great to know lol Thanks Mike Link to comment Share on other sites More sharing options...
SBT Posted June 27, 2012 Share Posted June 27, 2012 Just did this on my 1998 BD5 LGT w/NA EJ25D. I could draw huge circles with the shifter in any gear, now it's snick, snick again. Love it. Here's the walk-through link you want with pictures and all of the how-to you'll need. My write-up is at the end of that thread, post #63. Good luck and report back on how it goes. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
