FMS to Stock Downpipe
So I'm planning on installing the FMS cat back next weekend and am trying to get everything I need gaskets and adapters wise.
My question is, what is the best way to go from the stock downpipe to the 3" FMS mid pipe?
I've seen the grimmspeed adapter to go from 3" dp to stock mid, but nothing to go the other way around. Will a simple 3" flat gasket do the trick or do I need something more involved?
Any tips are greatly appreciated, thanks!!
you can also search, this has been covered millions of times or PM vendors they will help you
StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap
