slonez Posted June 11, 2012 Share Posted June 11, 2012 Hi Guys! Looking to install the widest 17" on a 06 LGT. What i the correct wheel specification? Willing to roll fenders. Thank you. Link to comment Share on other sites More sharing options...
Drift Motion Posted June 11, 2012 Share Posted June 11, 2012 17x9 +35 235 or 245s Link to comment Share on other sites More sharing options...
whitetiger Posted June 11, 2012 Share Posted June 11, 2012 you can do a 245 tire on a 8" wide +48 wheel and not have to roll that much if at all depending on your alignment and ride height. if you want a 17x9 wheel, try for a 255 wide tire, but you will need roll/pull and the right alignment. Link to comment Share on other sites More sharing options...
slonez Posted June 12, 2012 Author Share Posted June 12, 2012 Do you think 17 x 8.5 offset 48 is going to cause problem assuming I rolled the fenders for all 4 wheels? Tires are 245/45R17. Link to comment Share on other sites More sharing options...
whitetiger Posted June 12, 2012 Share Posted June 12, 2012 it all depends on the tire. its never the rim that rubs, just the tire. so what size are you gonna decide to get, and ill tell you if it will fit easily. Link to comment Share on other sites More sharing options...
slonez Posted June 13, 2012 Author Share Posted June 13, 2012 Tire size is 245/45R17 Thks for your advise. Link to comment Share on other sites More sharing options...
whitetiger Posted June 13, 2012 Share Posted June 13, 2012 a better size, closer to stock diameter, would be 245/40/17 and you will be more than fine with a modest fender roll. i DD that exact size on a 8" wide rim +48. Link to comment Share on other sites More sharing options...
slonez Posted June 13, 2012 Author Share Posted June 13, 2012 Thank you. Link to comment Share on other sites More sharing options...
