car_cursed Posted June 9, 2012 Share Posted June 9, 2012 Okay, I have searched and read all of the threads, I have a front Drivers side rattle/squeak, that is driving me nuts and before I start replacing (more) parts one at a time I would like anyones opinion on what to do. The Car: 2006 Legacy GT 72k miles Stock suspension except Rallitek endlinks The Problem: On bumpy/uneven roads the front drivers side suspension creates a noticeable rattle/squeak, I can feel the rattle in the floor under my foot when it is resting on the dead pedal. The Resolutions (so far): I have replaced and double checked the endlinks (rallitek) I have greased the stock sway bar bushings I have tightened every nut under the car and tightened the strut mount nuts in the engine bay The LCA bushing look new There is no play in the wheel bearings or ball joint Replaced the axle No leaks from the strut Lateral links do not Other Posibilities (how can i check these?) Sway bushings are worn and greasing them did nothing Strut mount (how can I check this?) Main Strut nut (how can I check this?) Think I might try disconnecting the endlink to see if that eliminates the rattle if it does then it's the sway mounts, if not it's ????? New problem listed Below Okay, I am getting a popping noise coming from my drivers side, I have swapped, and properly torqued my Rallitek endlinks, greased the bushings, it sounds like it's coming from the strut maybe the it happens when I turn to almost full lock and then will cause the car to pull untill I turn the opposite direction to un bind it.. The noise did not start until I tightened the main strut nut that was loose and causing a rattle. I did not replace the sway bars, just did not want to make a new thread. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 9, 2012 Share Posted June 9, 2012 It could be worn swaybar bushings. Also, I know you said you checked them but the bushings on the rear of the front lca could be the culprit. I haven't seen many last 70k+ miles and still be in good shape. Even before they completely crack, they still allow way more deflection than desired. Link to comment Share on other sites More sharing options...
car_cursed Posted June 10, 2012 Author Share Posted June 10, 2012 Damn it, it was the main strut nut, it was finger loose. Tightened it up, and all is good. Link to comment Share on other sites More sharing options...
car_cursed Posted July 16, 2012 Author Share Posted July 16, 2012 New Noise after I fixed the old noise bump. Okay, I am getting a popping noise coming from my drivers side, I have swapped, and properly torqued my Rallitek endlinks, greased the bushings, it sounds like it's coming from the strut maybe the ball joint? It happens when I turn to almost full lock and then will cause the car to pull untill I turn the opposite direction to un bind it. The noise did not start until I tightened the main strut nut that was loose and causing a rattle. I did not replace the sway bars, just did not want to make a new thread. Link to comment Share on other sites More sharing options...
dan04103 Posted July 23, 2012 Share Posted July 23, 2012 I am not sure if it's the ball joint or not. My experience with ball joints is it makes a noise when hitting bumps while driving typically at lower speeds unless its a bigger bump. Sounds like an issue with your springs to me. Only pops when turning? Sounds like your top spring hat isn't aligned properly. Which if your strut bolt was loose would make sense. Good luck! Link to comment Share on other sites More sharing options...
wiscogtlimited Posted July 26, 2012 Share Posted July 26, 2012 I seem to be having a similar issue with my 2005 LGT and I am stumped myself. If you figure out a solution, let me know. I am getting my wheels rotated and balanced tomorrow from the subie dealer, and they may be able to give me the skinny on what is going on. Link to comment Share on other sites More sharing options...
car_cursed Posted July 26, 2012 Author Share Posted July 26, 2012 alright, I loosened the main strut nut, compressed the suspension and re-tightened using a pass through and allen wrench. Still making noise, I am going to disconnect the sway bar next to eliminate that, it looks like it is making my tire wear on the outside much too fast. I'll update with any results. Link to comment Share on other sites More sharing options...
wiscogtlimited Posted July 27, 2012 Share Posted July 27, 2012 Dealer diagnosed my issue as bad sway bar links. Rotate + balance plus repair cost $230 @ sommers subaru in mequon wi. Not terrible. Link to comment Share on other sites More sharing options...
car_cursed Posted July 27, 2012 Author Share Posted July 27, 2012 Yeah, i hope that's not it or I'll be calling Rallitek Link to comment Share on other sites More sharing options...
car_cursed Posted July 31, 2012 Author Share Posted July 31, 2012 found the problem, looks like the top hat is seized. Link to comment Share on other sites More sharing options...
mbova23 Posted July 23, 2013 Share Posted July 23, 2013 Top hat? Link to comment Share on other sites More sharing options...
driving Posted August 5, 2013 Share Posted August 5, 2013 I had same problem when I installed new springs and shocks my buddy rushed me (his place couldn't use air tools after ten pm) anyway the washer was in the wrong spot so the bearing was grinding. Fixed it the next day. Washer is tapered to fit small side up. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 8, 2013 Share Posted August 8, 2013 At 70k it doesn't suprise me that the upper mounts are seized. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
