SpecBamf41 Posted May 25, 2012 Share Posted May 25, 2012 I got my 5 speed in and its a cable clutch. My problem is that of the 8 plus pedal push only an inch or so are useable to feather the clutch in and out. Plus that inch or so is right within the first 3 inches of the pedals range. Making it very hard to let the clutch out smooth cause I gotta have my foot so far back. Though I still have to push alll The way in to get into first and reverse. I can move the engage range closer to the floor but then it always grinds. Also is there a different cough and plate combine I can buy that will lenghten the range from full engage to full disengauge Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
heresmymind Posted May 25, 2012 Share Posted May 25, 2012 it should engage near the top... thats how my brand new ACT clutch is, i love it. and for first/reverse it is always pushed 100% down. -B Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 26, 2012 Author Share Posted May 26, 2012 how do you control it much when your damn near pointing at yourself with your toe. is there any way you can spread the engage disengage sweep instead of my one inch or so. BNR18g on 93oct Link to comment Share on other sites More sharing options...
heresmymind Posted May 26, 2012 Share Posted May 26, 2012 Plush the seat back and angle your seat forwards! The more you wear it in the lower it will engage. My clutch requires 1.5" from the top to shift. But when going to start it or from a stop I push all the way in. You just get used to it. -B Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 27, 2012 Author Share Posted May 27, 2012 i set with my back straight up and far enough forward to control the gas pedal with my toes. always have, now i have this third pedal ******* everything up. BNR18g on 93oct Link to comment Share on other sites More sharing options...
