CousinLarry Posted May 21, 2012 Share Posted May 21, 2012 Has anyone tried welding an E-cutout to the stock downpipe?! So you could run full stock exhaust but open it up when you want.. I had a 1998 Camaro SS with an e-cutout and I loved it. I wonder though if you could run the stage 2 map at all times with it open and closed? Any downsides? Link to comment Share on other sites More sharing options...
bmx045 Posted May 21, 2012 Share Posted May 21, 2012 no. you would gain 0 horseforces. look at the flat plate on the stock downpipe, there's your answer. you cant run stage 2 on the stock dp unless you gut it out, that can give you a little more room to work your way up on boost, the flow is still decently restricted because of the plate Link to comment Share on other sites More sharing options...
CousinLarry Posted May 21, 2012 Author Share Posted May 21, 2012 Yeah, I forgot about that plate. Oh well. Link to comment Share on other sites More sharing options...
