Lightro Posted May 17, 2012 Share Posted May 17, 2012 Car: 1995 Subaru Legacy L 2.2L AWD Code: P0304 Cylinder 4 misfire code just posted yesterday. Symptoms: TERRIBLE gas mileage 8-9mpg, jerks when accelerates, hesitates when i step on gas if the car is cold. Opinions??? Link to comment Share on other sites More sharing options...
johnegg Posted May 17, 2012 Share Posted May 17, 2012 tune up time. NGK plugs, subaru wires, PVC, air filter, oil filter.........? other things that will kill mpg, dragging brakes, bad o2 or knock sensors, lots of idling. how many miles on this car? how long have you had it? has it always run like this? Link to comment Share on other sites More sharing options...
Lightro Posted May 17, 2012 Author Share Posted May 17, 2012 tune up time. NGK plugs, subaru wires, PVC, air filter, oil filter.........? other things that will kill mpg, dragging brakes, bad o2 or knock sensors, lots of idling. how many miles on this car? how long have you had it? has it always run like this? Has 155k owned it for 5 years and put 35k on it. Was in an accident last July and was hit on the front right...replaced fender Hood bumper cover...didn't notice any engine problems until recently. Past 2-3 months the mileage been getting worse until finally a code posted which is staying. Was initially thinking o2 sensors since it is dumping out gas and running rich, but am not sure. Spark plugs oil filter all serviced...timing belt and water pump as well Link to comment Share on other sites More sharing options...
