Joaks Posted May 16, 2012 Share Posted May 16, 2012 I knocked off a hose and my CEL came on. Does anyone know how long it will take to reset? Thanks! Link to comment Share on other sites More sharing options...
johnegg Posted May 16, 2012 Share Posted May 16, 2012 2 drive cycles unless you disconnect the battery for several hours or use a code reader. BUT if the problem still exists, the code will not reset. Link to comment Share on other sites More sharing options...
Joaks Posted May 16, 2012 Author Share Posted May 16, 2012 Drive cycle = drive and turn the car off? I replaced the hose but I've driven three times so far. Nevermind. Looked it up on the OBD page. Link to comment Share on other sites More sharing options...
gergeek Posted May 16, 2012 Share Posted May 16, 2012 its like 60 miles or so for it to reset itself i think, u can just find someone with a scanner to reset it for you Link to comment Share on other sites More sharing options...
johnegg Posted May 16, 2012 Share Posted May 16, 2012 so, now that you know, share. or are you one of those guys who only asks questions, not answer them? Link to comment Share on other sites More sharing options...
Joaks Posted May 16, 2012 Author Share Posted May 16, 2012 This is what I found online. Not subaru specific and I have not tested it (so I don't know if it works). I thought I heard somewhere any 40min drive would work but not sure on that either! (Note: Drive cycle specifics vary by vehicle!) 1. Ensure that the fuel tank is between 1/4 and 3/4 full. 2. Start cold (below 86°F /30°C) and warm up until engine coolant temperature is at least 160° F (typically requires at least one minute; up to 3 minutes). 3. Accelerate to 40-55 MPH at 25% throttle and maintain speed for five minutes. 4. Decelerate without using the brake (coast down) to 20 MPH or less, then stop the vehicle. Allow the engine to idlefor 10 seconds, turn the key off, and waitone minute. 5. Restart and accelerate to 40-55 MPH at 25% throttle and maintain speed for two minutes. 6. Decelerate with using the brake [or the clutch!] by coasting down to 20 MPH or less, then stop the vehicle. Allow the engine to idle for 10 seconds, turn the key off, and wait one minute. Link to comment Share on other sites More sharing options...
