monkeyposeur Posted May 14, 2012 Share Posted May 14, 2012 I would like to remove the front mud flaps as I am painting the wagon tomorrow. The bolts just spin. I removed the mud guard so I could get a look at the back of the bolts with a dental mirror. There are two plastic tabs on both sides of the nut which will not allow my socket to fit over them. I also can't figure out if it is a 8 or 10 mm. There isn't any room to get a wrench back there either. It seems as though I would have to take the whole fender off to gain access to the bolts to get them off. I don't really feel like doing that. Any tips? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 14, 2012 Share Posted May 14, 2012 I just went through this. The tabs and bolts become so rusted from salt spray that there are very few options to remove them. I ended up bending the fender lip out slightly so that I could fit a pair of lock-jaws to the bolt, clamped down as hard as I could to keep it from spilling and then drilled out the bolt. Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 15, 2012 Author Share Posted May 15, 2012 Thanks. That was what I was afraid of. edit: I will just leave them in place and pry them away from the body when I shoot the paint. Link to comment Share on other sites More sharing options...
