jamaha51 Posted May 12, 2012 Share Posted May 12, 2012 So today I tried to measure my valve shims so I could order new ones but I can't get them out. A guy from another forum said he could use a screwdriver to pry against the buckets instead of the special tool, but I had no luck doing what he did. I know that I could take out the cams but I really dont want to do that. Does anybody have advise on this or the special tool I could rent? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted May 13, 2012 Share Posted May 13, 2012 Removing the cam's is not a hard task at all. Well I guess if the timing components are still on the car thing its more work. But not hard. Shit now I know why I should of done them when the heads were off. For got about the timing belt. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
monkeyposeur Posted May 13, 2012 Share Posted May 13, 2012 I thought that this was a good HG DIY with some good pics of his cams and how he measured the shims: http://home.comcast.net/~skipnospam/Head_gasket_replacement.html I think he pulled removed the cams though. It's not that hard, I did it on my SS. However, you would need to be a bit more careful removing the rocker assembly since you don't have HLAs. Keep everything in order. Link to comment Share on other sites More sharing options...
subikid90 Posted May 14, 2012 Share Posted May 14, 2012 If you cant get them out they are steel, use a magnet, works every time for me. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
jamaha51 Posted May 14, 2012 Author Share Posted May 14, 2012 The problem is pushing the buckets down while pulling the shims out. I don't want to pull the cams so maybe I will wait to see if it overheats this summer. The PO said it would overheat and if I have to do headgaskets I will do it at the same time. Link to comment Share on other sites More sharing options...
jamaha51 Posted May 15, 2012 Author Share Posted May 15, 2012 Ok, I found this but does anybody know if it would work? http://www.monstermarketplace.com/automotive-specialty-tools-and-equipment/subaru-valve-shim-replacer-498187100 This is the one that is specifically made for subarus. http://www.etoolcart.com/subaru-valve-shim-replacer-498187100.aspx Link to comment Share on other sites More sharing options...
