nismohrdbody Posted May 11, 2012 Share Posted May 11, 2012 hey guys, so about a month or so ago, i was having issues with my gt, being real sluggish, and stuttering, at low rpms. once i reached about 3-4 grand it would throw me back in the seat. i changed the plugs, and the problem went away for about 4weeks, but the same problem is back. i have been reading about the injectors going bad, how its not un-common, but i have no codes.....??? any ideas? Link to comment Share on other sites More sharing options...
bmx045 Posted May 11, 2012 Share Posted May 11, 2012 clean your maf sensor Link to comment Share on other sites More sharing options...
nismohrdbody Posted May 11, 2012 Author Share Posted May 11, 2012 what can i use to clean it with? Link to comment Share on other sites More sharing options...
Nrw Posted May 11, 2012 Share Posted May 11, 2012 http://www.m5board.com/vbulletin/attachments/m5-e39-e60-tips-tricks/54440d1198700104-tech-clean-your-maf-dont-replace-maf-cleaner.jpg Link to comment Share on other sites More sharing options...
bmx045 Posted May 11, 2012 Share Posted May 11, 2012 yes, maf cleaner is a good cleaner for your maf. I know everything about maf theory. Link to comment Share on other sites More sharing options...
nismohrdbody Posted May 11, 2012 Author Share Posted May 11, 2012 cool thanks Link to comment Share on other sites More sharing options...
nismohrdbody Posted May 13, 2012 Author Share Posted May 13, 2012 ok i got the maf sensor cleaner, and sprayed it on both sides of sensor, generously. it didnt seem to help. i noticed that the center pin on the maf sensor was brownish gold, but it didnt look corroded. is that normal? also the center pin wire was red with blue stripe, going into a gray wire sleave. is that normal? Link to comment Share on other sites More sharing options...
ericem Posted May 13, 2012 Share Posted May 13, 2012 look for a boost leak or intake leak. Link to comment Share on other sites More sharing options...
bmx045 Posted May 13, 2012 Share Posted May 13, 2012 the iat sensor bulb should be amber in color, it usually becomes black on one side when dirt collects, the more important part is spraying up into the maf tube where the filaments lay. those have a red stripe Link to comment Share on other sites More sharing options...
nismohrdbody Posted May 13, 2012 Author Share Posted May 13, 2012 i was actually talking about the 5 pin connector that you have to unplug before removing the intake box. Link to comment Share on other sites More sharing options...
bmx045 Posted May 13, 2012 Share Posted May 13, 2012 lol. why are you cleaning that? the connector is not what you clean Link to comment Share on other sites More sharing options...
nismohrdbody Posted May 13, 2012 Author Share Posted May 13, 2012 i didnt. i sprayed it on the sensor its self. i guess i just worded my sentence poorly. Â so is that pin supposed to be brown or silver like the rest.? Link to comment Share on other sites More sharing options...
bmx045 Posted May 13, 2012 Share Posted May 13, 2012 the middle one is suppsoe to be gold colored Link to comment Share on other sites More sharing options...
nismohrdbody Posted May 13, 2012 Author Share Posted May 13, 2012 ok thanks, i guess ill look for a intake leak. Link to comment Share on other sites More sharing options...
nismohrdbody Posted June 22, 2012 Author Share Posted June 22, 2012 ok so the problem went away for a little while. but now its back and seems worse this time around. i couldn't find any kinda of leaks. could it be the injectors or the turbo? Link to comment Share on other sites More sharing options...
ragman Posted June 22, 2012 Share Posted June 22, 2012 Reset the ECU....easy non technical way is to unhook the negative ground cable on the battery for a couple minutes, then hook back up. Link to comment Share on other sites More sharing options...
ScoobyGT15 Posted June 22, 2012 Share Posted June 22, 2012 I don't think it would be the turbo. That doesn't seem to make sense if it is sluggish in low RPM and then when it gets higher throws you back. That sounds like that turbo is working perfectly fine to me. I would do a little more research on those injectors and see what you can find. How many miles do you have? Link to comment Share on other sites More sharing options...
nismohrdbody Posted June 27, 2012 Author Share Posted June 27, 2012 i have 88k on the car right now. ive heard the yellow top injectors suck, and crap out. but i thought when a injector goes bad its totally stops working. not on and off. when i did the tune up i might have seen some arcing on the two of the four coil packs but im not certain that it was really arcing. Link to comment Share on other sites More sharing options...
ScoobyGT15 Posted June 27, 2012 Share Posted June 27, 2012 i have 88k on the car right now. ive heard the yellow top injectors suck, and crap out. but i thought when a injector goes bad its totally stops working. not on and off. when i did the tune up i might have seen some arcing on the two of the four coil packs but im not certain that it was really arcing. If you have arcing I would say you have quite a big problem. I've never heard of arcing in a car before. That sounds like an electrical fire just waiting to happen. Link to comment Share on other sites More sharing options...
