Subimods Posted May 10, 2012 Share Posted May 10, 2012 http://img16.imageshack.us/img16/8646/iscslider.jpg Purchase your set of ISC Coilovers in the Month of May and receive a $25 gift card to redeem on your next purchase!! All coilovers come with a 12 month warranty to put your mind at ease, if our product fails in any way in the first 12 months we will pay all postage, labor and parts costs to fix the issue in minimal time. If our product fails after that initial 12 month period we will replace the product at trade price! We never stop looking after our customers. The N1 coilover can be lowered approximately 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically. we make packages for track/rally/drag and of course street, to help our customers out even more we give them the option to pick there own custom spring rates at no extra charge. 32 Step Damper Adjustable * Precise control damp valve * Operates smoothly on all road surfaces * Expansion/Suppression of shock adjustment Pillowball Uppermount * Adjustable camber allows more/less on road track for all conditions Piston Rod Design * High rigidity steel piston rods * Meets with race/sport standards Sports Spring * Made from high quality SAE9254 steel * Tested over 500,000 times on compression inspection with less than 5% deformation. Ride Height Adjustable * Full length height adjustable * Bound adjustable with separate spring locks * High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force Aluminium Bracket * Made from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance * Specifically anodised surface to prevent inside corrosion and surface rust * On various models camber can also be adjusted via the bracket as well as the camber tops Single Cylinder Design * Larger cylinder and piston design to advance driving stability and dexterity Spring Rate: Street Sport 8k Front / 6k Rear Racing/Drift: 10k Front / 8k Rear PM OR CALL US TO PLACE AN ORDER - 8602910015 Link to comment Share on other sites More sharing options...
Subimods Posted May 11, 2012 Author Share Posted May 11, 2012 TGIF... get some coilovers to make it even better Link to comment Share on other sites More sharing options...
Subimods Posted May 14, 2012 Author Share Posted May 14, 2012 lets sell some ISC coilovers guys!! Link to comment Share on other sites More sharing options...
Subimods Posted May 16, 2012 Author Share Posted May 16, 2012 Bump for some coils Link to comment Share on other sites More sharing options...
Subimods Posted May 22, 2012 Author Share Posted May 22, 2012 Tuesday time for some coilovers Link to comment Share on other sites More sharing options...
waduga Posted May 24, 2012 Share Posted May 24, 2012 Will they fit a 2005 legacy gt wagon? Link to comment Share on other sites More sharing options...
Subimods Posted May 25, 2012 Author Share Posted May 25, 2012 PM'd Sir Link to comment Share on other sites More sharing options...
Subimods Posted May 28, 2012 Author Share Posted May 28, 2012 all pm's replied thanks guys Link to comment Share on other sites More sharing options...
Subimods Posted July 23, 2012 Author Share Posted July 23, 2012 to the top! Link to comment Share on other sites More sharing options...
Subimods Posted September 7, 2012 Author Share Posted September 7, 2012 get your set today! Link to comment Share on other sites More sharing options...
