kirbwrx Posted May 7, 2012 Share Posted May 7, 2012 Please let me know if everything looks good. Thanks in advance. Timdatalog2.csv Link to comment Share on other sites More sharing options...
brad_houck Posted May 10, 2012 Share Posted May 10, 2012 something is messed up with the tables in your log. it appears to all be in one column and you cant read it correctly. Link to comment Share on other sites More sharing options...
kirbwrx Posted May 10, 2012 Author Share Posted May 10, 2012 Second attempt.Datalog7May2012.csv Link to comment Share on other sites More sharing options...
bmx045 Posted May 10, 2012 Share Posted May 10, 2012 add engine load to the parameters but you have a decent amount of knock on spool up, boost leak test it at all? Link to comment Share on other sites More sharing options...
kirbwrx Posted May 10, 2012 Author Share Posted May 10, 2012 Thank you for your input. Ill try to do another log soon but its been really windy the last few days. How do i do a leak test and why do you think that needs to be done. Link to comment Share on other sites More sharing options...
iNVAR Posted May 10, 2012 Share Posted May 10, 2012 engine load is there. column d don't know what a spec b twinscroll is supposed to put out, but he's pushing 19.8+ psi and knocking right in that area. and if that's a 3rd/4th gear log, 5th or 6th will likely spike higher and sooner, hence the slight FLKC you see at 2700rpm Link to comment Share on other sites More sharing options...
bmx045 Posted May 10, 2012 Share Posted May 10, 2012 to determine if you have a vac leak pre turbo, meaning an unmetered lean spool up thus knock events. google "boost leak test legacygt.com" it's been mentioned a lot Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 11, 2012 Share Posted May 11, 2012 You should get a wideband and/or use something to log with better resolution. I can 3-4x the resolution using romraider's fast polling. It helps on the the fast transition parts(such as spool). Link to comment Share on other sites More sharing options...
