Gemini91 Posted May 7, 2012 Share Posted May 7, 2012 I added 4quarts new oil in the oil change and noticed the oil lever was way higher than the "full" mark on the stick. When I start engine there is white smoke coming out from the exhaust for about 1 second. The smoke smells like somthing is burnt.. But after that the car still runs as usual. I think maybe it's the coolant leak? But I checked the coolant tank in these two days and didnt find obvious change of the coolant level. I think there must be something mixing with my oil? but what is it? Link to comment Share on other sites More sharing options...
Gemini91 Posted May 7, 2012 Author Share Posted May 7, 2012 Ok,after sucking some oil out, I see the drop of coolant level... Link to comment Share on other sites More sharing options...
austin42008 Posted May 7, 2012 Share Posted May 7, 2012 Their is prob just 2 much oil. Like you said it is showing more oil then full. Do another oil change and make sure it all drains out. The smokeing is your motor burining the extra oil prob. Link to comment Share on other sites More sharing options...
Gemini91 Posted May 8, 2012 Author Share Posted May 8, 2012 but 4 quarts is that much? according to the user manual, oil capacity is more than that Link to comment Share on other sites More sharing options...
Vinny78 Posted May 8, 2012 Share Posted May 8, 2012 are you sure you drained the oil pan and not the trans pan plug, its easy to get mixed up Link to comment Share on other sites More sharing options...
Vinny78 Posted May 8, 2012 Share Posted May 8, 2012 there could actually be 8 quarts and no transfluid. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted May 8, 2012 Mega Users Share Posted May 8, 2012 are you sure you drained the oil pan and not the trans pan plug, its easy to get mixed up this almost sounds like whats going on. how the ef could you mix that up. one bolts is on the transmission and is a torx bolt, and the other is on a pan and is a metric bolt:confused: "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Gemini91 Posted May 8, 2012 Author Share Posted May 8, 2012 this almost sounds like whats going on. how the ef could you mix that up. one bolts is on the transmission and is a torx bolt, and the other is on a pan and is a metric bolt:confused: You guys are right. Just noticed I drained my differential gear oil:eek:, which makes me feel I'm really stupid... But I still have a silly question about motor oil. I removed the oil filter during "oil change" and got plenty of oil out after that. So simply removing the oil filter cannot get all oil out? Link to comment Share on other sites More sharing options...
Vinny78 Posted May 8, 2012 Share Posted May 8, 2012 That is correct, the oil filter will not act as a drain plug itsself. It will not get all the oil out! Link to comment Share on other sites More sharing options...
pillboy Posted May 8, 2012 Share Posted May 8, 2012 Sounds like OP is a Jiffy Lube employee. It is still ugly. Link to comment Share on other sites More sharing options...
Vinny78 Posted May 9, 2012 Share Posted May 9, 2012 Haha oh man thats not right =p Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted May 9, 2012 Share Posted May 9, 2012 This folks, is why I have an aversion to buying used cars. There is just no knowing what kinds of crazy sh!t the previous owners have done. Link to comment Share on other sites More sharing options...
W.K.S. Posted May 9, 2012 Share Posted May 9, 2012 You guys are right. Just noticed I drained my differential gear oil:eek:, which makes me feel I'm really stupid... But I still have a silly question about motor oil. I removed the oil filter during "oil change" and got plenty of oil out after that. So simply removing the oil filter cannot get all oil out? Nope. you need to train the pan, and the only way to do that is to remove the plug (or simply open the fumoto valve ) usually drain the oil pan first then use the solo cup trick (put cup around the filter then unscrew it) to minimize oil getting onto the manifold and stinking up the cabin when it burns off. Another trick I like to use is to hammer a screwdriver into the bottom of the filter then move the catch pan under it, and drain the oil out before you take the filter off. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 12, 2012 Share Posted May 12, 2012 You will get very little oil out by removing only the filter! Most of the oil will be in the pan which sits lower than the filter. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 12, 2012 Share Posted May 12, 2012 http://i408.photobucket.com/albums/pp166/crf150yo/vinny-2-4.jpg Link to comment Share on other sites More sharing options...
iNVAR Posted May 12, 2012 Share Posted May 12, 2012 this almost sounds like whats going on. how the ef could you mix that up. one bolts is on the transmission and is a torx bolt, and the other is on a pan and is a metric bolt:confused: yeah, seriously, how does this happen? unless automatics use a diff bolt or something Link to comment Share on other sites More sharing options...
bmx045 Posted May 16, 2012 Share Posted May 16, 2012 8 quarts of oil not enough Link to comment Share on other sites More sharing options...
AZP Installs Posted May 16, 2012 Share Posted May 16, 2012 yeah, seriously, how does this happen? unless automatics use a diff bolt or something The drain for the front diffy on at cars is not the hex/star bolt. It is a regular bolt and is relatively far forward. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
iNVAR Posted May 16, 2012 Share Posted May 16, 2012 Ah ha! So that's it... DOH. Link to comment Share on other sites More sharing options...
