Utmost Posted May 4, 2012 Share Posted May 4, 2012 The rubber lining on the inside edge of my wheel well is peeling away. Any suggestions as the the most effective, clean way to re-attach it? Link to comment Share on other sites More sharing options...
pillboy Posted May 4, 2012 Share Posted May 4, 2012 Get a new one. They are just press-fit onto the fender lip. I had to replace both of mine. They start "peeling" away because there is a metal core and it starts to rust at the ends where the material is cut and the metal "swells" inside the rubber and causes the liner to pull away. If I remember correctly, they are about $15 each. It is still ugly. Link to comment Share on other sites More sharing options...
Utmost Posted May 7, 2012 Author Share Posted May 7, 2012 replace em... easy peasy... cheers! Link to comment Share on other sites More sharing options...
DoctorLGT Posted May 7, 2012 Share Posted May 7, 2012 Rear or front? Link to comment Share on other sites More sharing options...
Utmost Posted May 7, 2012 Author Share Posted May 7, 2012 Drivers side rear. Figure I'll replace em both. Link to comment Share on other sites More sharing options...
W.K.S. Posted May 7, 2012 Share Posted May 7, 2012 take em off, nothing lost really. Link to comment Share on other sites More sharing options...
Bdubs Posted May 13, 2012 Share Posted May 13, 2012 If you are going to replace them, be sure to take them off from time to time to get all the road debris out of there. That will for sure cause a corrosion issue down the road. I just took mine off, and left them off. Link to comment Share on other sites More sharing options...
Utmost Posted May 14, 2012 Author Share Posted May 14, 2012 Guess I'll yank 'em, put that $30 towards my LCA bushings. Link to comment Share on other sites More sharing options...
SpecBGuy Posted May 14, 2012 Share Posted May 14, 2012 i had no choice but to take mine off since my tires ripped half of it off. it makes the car look better imo. Link to comment Share on other sites More sharing options...
