StoplightAssassin Posted May 2, 2012 Share Posted May 2, 2012 I didn't know what surging was until yesterday but after I went out for a cruise with a few friends of mine I definitely noticed the car surging. Forgot to repost here. I really can't see it NOT being the front O2 at this point. O2 sensors can be as fragile as light bulbs. If they banged it, or removed it to change the axle it could definitely disturb it and cause it to malfunction. I just replaced mine maybe 6 weeks ago after a header install due to this issue. Link to comment Share on other sites More sharing options...
whitetiger Posted May 2, 2012 Share Posted May 2, 2012 ^exactly why i brought it up. Link to comment Share on other sites More sharing options...
Buzzman Posted May 2, 2012 Author Share Posted May 2, 2012 Is it hard to replace? Link to comment Share on other sites More sharing options...
whitetiger Posted May 2, 2012 Share Posted May 2, 2012 no. 30 minutes with hand tools Link to comment Share on other sites More sharing options...
Buzzman Posted May 2, 2012 Author Share Posted May 2, 2012 Ok can I pick up another 02 sensor from anywhere? Thanks for the help. Link to comment Share on other sites More sharing options...
whitetiger Posted May 2, 2012 Share Posted May 2, 2012 they often come with different calibrations. buy it at the dealer to ensure its the right one. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted May 2, 2012 Share Posted May 2, 2012 This is the part number for the front o2 for 05-07: 22641AA32A Fred Beans has the cheapest price between themselves, Cherry Hill, and Prestige. And you'll definitely want an o2 socket if you don't have one. They are ridiculous to get out without one. Link to comment Share on other sites More sharing options...
whitetiger Posted May 2, 2012 Share Posted May 2, 2012 bah. 7/8" box end wrench works great. never had an issue even with the rustiest of sensors. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted May 2, 2012 Share Posted May 2, 2012 I had the worst time getting my old one out. I had to hack up that little shield on the sensor and still couldn't get it. It was so worth the $5 bucks or whatever it was. Link to comment Share on other sites More sharing options...
whitetiger Posted May 2, 2012 Share Posted May 2, 2012 the trick is to disconnect the connector and put it through the closed end of the wrench so you can put the wrench on the sensor well. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted May 2, 2012 Share Posted May 2, 2012 Did that! I needed more torque. I finally had to put it on my 24" breaker bar and pull hard as hell...and you know how big I am lol. Link to comment Share on other sites More sharing options...
stanjk3 Posted May 4, 2012 Share Posted May 4, 2012 I still have a rough idle, even after changing the air filter and disconnecting the battery. But if I shift into Neutral when stopped at a stop sign or red light, its smooth as butter. Had my front-right drive shaft replaced in Dec 2009, also had a torn boot that was leaking grease. Seems like I'm not the only person that's had this issue with an aftermarket drive shaft. edit: Is it affecting your MPG? I usually get ~18MPG, though I do a lot of stop & go driving. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
Buzzman Posted May 4, 2012 Author Share Posted May 4, 2012 I don't think it has affected my gas mileage, still averaging 17mpg. However, like you suggested, neutral is smooth as butter. I'll probably replace my front 02 sensor this weekend and see what happens. Link to comment Share on other sites More sharing options...
