Joaks Posted April 29, 2012 Share Posted April 29, 2012 I have a little oil seep from the oil filler neck. The bolts seem tight. I assume there is a gasket there that I should replace (?) Link to comment Share on other sites More sharing options...
johnegg Posted April 29, 2012 Share Posted April 29, 2012 an o-ring, item #5, same for all H4 engines 90 - 04, at least. probably more. http://opposedforces.com/parts/legacy/us_b11/type_7/lubrication_system/oil_filler_duct/illustration_1/ Link to comment Share on other sites More sharing options...
powpowdreamz Posted January 4, 2016 Share Posted January 4, 2016 How did you tighten the bolts after you guys replaced this o-ring? i cant manage to get the bolts out without trying to remove some metal housing that is right there Link to comment Share on other sites More sharing options...
johnegg Posted January 4, 2016 Share Posted January 4, 2016 with a long, very long?, 3/8 inch, maybe a 1/4 inch, drive extension. it moves the ratchet up around the oil fill cap. is that what you wanted to know? Link to comment Share on other sites More sharing options...
powpowdreamz Posted January 5, 2016 Share Posted January 5, 2016 Yeah that is what i wanted to know thank you very much, i'll give that a try today. Link to comment Share on other sites More sharing options...
powpowdreamz Posted January 5, 2016 Share Posted January 5, 2016 also when you install the o-ring do you just drop it in or do you put it on the oil fill tube? Link to comment Share on other sites More sharing options...
johnegg Posted January 5, 2016 Share Posted January 5, 2016 youy'll see when you pull it. it fits on the bottom of the fill spout. Link to comment Share on other sites More sharing options...
powpowdreamz Posted January 6, 2016 Share Posted January 6, 2016 haha alright, well i didn't see if when i removed it because it turns out that is why my filler was loose the o-ring wasn't there. but that's what i did thanks for the help everybody, much appreciated. Link to comment Share on other sites More sharing options...
