Theride Posted April 27, 2012 Share Posted April 27, 2012 I just want this to be out there just in case anyone has to replace one and have no clue. 1. Secure car and jack up car properly. 2. Remove wheel 3. Remove caliper and hung it away with a piece of wire. 4. Use two 8mm 1.25 bolts to FORCE the rotors off the hub if they are hard to get off. These bolts are located on the car in many areas. Make sure you use two at once and tighten evenly until rotor is free. 5. Use a heavy hammer and knock the broken stud out. 6. Put new stud in and use a whole bunch of washers to PULL the new stud in place. 7. Put rotor on 8. Put caliper back on 9. Put wheel back on Done. SIDE NOTE: I did this on a 2009 Legacy 2.5 Limited Edition with AUTO. There was enough room to get the new stud in the whole so tricks were really use. Its a very very easy job that can be done in 20 mins. Link to comment Share on other sites More sharing options...
sahrbjr Posted May 1, 2012 Share Posted May 1, 2012 Your doing someone a favor I'm sure! Link to comment Share on other sites More sharing options...
kaclaytor Posted May 1, 2012 Share Posted May 1, 2012 I had to take the whole hub off. I was putting in extended studs though, maybe there would have been room for factory length studs Link to comment Share on other sites More sharing options...
