revD Posted April 20, 2012 Share Posted April 20, 2012 I went to replace my rear pads and came back with a set that didnt fit, so i returned to the store with the pas to match and it turns out I have N/A rear calipers, or atleast pads? Has anyone else found this? What other differences might there be? Maybe the catolog at the store was off.. trying to find the part #'s i used Link to comment Share on other sites More sharing options...
jamal Posted April 20, 2012 Share Posted April 20, 2012 the year of your lgt would be helpful. 05-09 lgt uses D770 pad shape which is also found on the 99-03 impreza and 00-04 legacy. 05-09 non-turbo legacy uses D1114 which is also on the 08+ impreza the pad shapes are a FMSI standard number that many manufacturers use in the actual part number (i.e. stoptech/centric) or at least have a cross reference sheet available (hawk). so for example the correct stoptech part number for an LGT is 309.07700 http://forums.nasioc.com/forums/showthread.php?t=1265631 Link to comment Share on other sites More sharing options...
revD Posted April 21, 2012 Author Share Posted April 21, 2012 I have a 2005. Link to comment Share on other sites More sharing options...
