brad_houck Posted April 18, 2012 Share Posted April 18, 2012 can anyone help as to where these numbers are coming from. thanks in advanceLearningView_4-10-2012 5 47 07 PM.csv Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 18, 2012 Share Posted April 18, 2012 It appears to be a really unhappy engine, everywhere. Did you recently buy some bad gas? Lots more info on the car please, anything related to mechanical and software control. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
brad_houck Posted April 18, 2012 Author Share Posted April 18, 2012 its an 08 5 speed, catless downpipe, 3in exhaust, drop in filter, and infamous stg 2 tuned on the 3rd revision. i have gotten gas from giant twice within the past few months but its usually shell or sunoco. Link to comment Share on other sites More sharing options...
bmx045 Posted April 19, 2012 Share Posted April 19, 2012 does your car consume oil? Link to comment Share on other sites More sharing options...
brad_houck Posted April 19, 2012 Author Share Posted April 19, 2012 i usually have to put in a little less than a qt every 3k miles. Link to comment Share on other sites More sharing options...
bmx045 Posted April 19, 2012 Share Posted April 19, 2012 hmmm, a compression test wouldn't hurt. that's a lot of knock, assuming you didnt repeatedly get bad gas Link to comment Share on other sites More sharing options...
brad_houck Posted April 19, 2012 Author Share Posted April 19, 2012 should i worry about the positives ones cuz i thought it was adding timing at those points? do you think i should reload the tune and drive it and pull another LV to see if anything changes? Link to comment Share on other sites More sharing options...
bmx045 Posted April 19, 2012 Share Posted April 19, 2012 your IAM is below 1. the ecu is slowly adding timing back in hopes it will clear up so it can get back to 1. you want the iam at 1. but your car is knocking so bad it's pulled timing across the entire timing table and slowly adding timing back to eventually reach 1 again..... oil in the combustion chamber can cause detonation and that comes from cracked ringlands Link to comment Share on other sites More sharing options...
brad_houck Posted April 19, 2012 Author Share Posted April 19, 2012 so if it goes back to 1 i should assume it was just bad gas Link to comment Share on other sites More sharing options...
iNVAR Posted April 19, 2012 Share Posted April 19, 2012 infamous is your tuner, and you're on your third revision. you really should be asking him about this. no telling what changes he made... or what the condition of the LV was prior to the changes, etc. Link to comment Share on other sites More sharing options...
brad_houck Posted April 19, 2012 Author Share Posted April 19, 2012 i did im waiting for him to email me back. i was just checking on here in the mean time. Link to comment Share on other sites More sharing options...
brad_houck Posted April 19, 2012 Author Share Posted April 19, 2012 this is one i just pulled today. Link to comment Share on other sites More sharing options...
bmx045 Posted April 19, 2012 Share Posted April 19, 2012 garbage, if it were my car i'd do a compression check. even in revision maps it shouldn't be dropping its IAM unless the revised timing tables are completely inappropriate, which is unlikely. either you have a bad air leak somewhere, really bad gas, or low compression in a cyl or more Link to comment Share on other sites More sharing options...
semsub Posted April 20, 2012 Share Posted April 20, 2012 this is one i just pulled today. This was mine LV screen on Infamous Rev 1 Rev 3 Here Rev 4 Now on Rev5 and LV screens looks clean Just wait for new rev, yep it tooks tooooo long to wait , but anyway wait ,wait Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 20, 2012 Share Posted April 20, 2012 Rev 5 does not look like you drove long enough to have the ECU learn anything. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
semsub Posted April 21, 2012 Share Posted April 21, 2012 Rev 5 does not look like you drove long enough to have the ECU learn anything. This is rev4 ,rev 5 is clean:) This is logs only after pulls Logs from after a week or so looks random,but nothing bad. When I start to panic after rev3 logs, Shamar told me it was part of tuning and later all will be ok, and now it is ok Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 21, 2012 Share Posted April 21, 2012 Oops, meant to say that about Rev 4 [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
brad_houck Posted April 23, 2012 Author Share Posted April 23, 2012 this is one i just pulled today. its been 4 days since the last one. is that long enough to learn knock? could it have just been bad gas? Link to comment Share on other sites More sharing options...
bmx045 Posted April 23, 2012 Share Posted April 23, 2012 looks good, i think you might have a rattle in the engine bay or something...right now Link to comment Share on other sites More sharing options...
brad_houck Posted May 23, 2012 Author Share Posted May 23, 2012 so through a combination of a smoke tester and a boost leak tester i found smoke coming out of this block off plate which appears to be on the tgvs. could this be why my car is adding fuel in the l/v? Link to comment Share on other sites More sharing options...
bmx045 Posted May 23, 2012 Share Posted May 23, 2012 Yes its possible. That area is under vacuum at idle and slight cruise and under positive pressure when on boost. Link to comment Share on other sites More sharing options...
bmx045 Posted May 23, 2012 Share Posted May 23, 2012 But really, that last posted learning view showed acceptable fuel trims. Within +\- 5%. And less than 1% for learned D range. But either way, eliminating any leaks is the best practice and will only help the way the car runs and idles. Link to comment Share on other sites More sharing options...
brad_houck Posted May 23, 2012 Author Share Posted May 23, 2012 ok cause thats the only place where smoke was coming out. now just to get to those screws... Link to comment Share on other sites More sharing options...
