bmx045 Posted April 17, 2012 Share Posted April 17, 2012 So I'm having a little bit of trouble wrapping my dome piece around the additive table. The only table I find in my 08 LGT rom is Timing Compensation B (IAT) Max Additive. I searched through RR forums and am somewhat confused- can anyone explain in simple terms what the purpose of this value/table is used for? How does this effect the base timing to KCA transition? does it effect the total timing the engine sees? Currently mine is at 0, not sure if I should revert it back to the oem 3 (based on an oem 08 LGT rom) Thanks Link to comment Share on other sites More sharing options...
