Mega Users paintpollz Posted April 17, 2012 Mega Users Share Posted April 17, 2012 This thread is primarily for the benefit/education of myself, hopefully it will help others. I bought used Perrin 1 Piece Catted DP that I've mated to my VF46 and stock CBE. In most situations, the car is much more pleasant to drive around in, now that I don't have the moaning and growning of the old Megan Racing CBE. Plus, I'm not sure there is another exhaust setup that looks as good as the stock cans tucked real nice. Anyways, I'm looking for more info on the performance differences between divorced and non divorced (bellmouth) downpipes. I've looked at some threads on Nasioc that say the divorced pipes will allow for more top end, others say its to keep the flow of the turbine as smooth as possible. Honestly, it all sounds like straight BS:rolleyes: Like I said before, in most situations, the car is much more pleasant to drive, exhaust tone wise. Where it falls short, is anywhere between 2600-3400 rpms. There is a moan in that rev range, not extremely viscous, but enough to be unpleasant on the highway with the music turned off. Some people I've talked to said that its the wastgate flapper hitting the divorced section in the DP:lol:. I think its the way the exhaust is flowing through the pipe, and the divorced piece in the pipe is causing a moan and groan that a conventional bellmouth design would not. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
m sprank Posted April 17, 2012 Share Posted April 17, 2012 It wont make a difference on a turbo that you install in your car. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted April 17, 2012 Author Mega Users Share Posted April 17, 2012 Mike, what do you think about my theory on the moaning in the 2600-3400 rev range? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
m sprank Posted April 17, 2012 Share Posted April 17, 2012 Not sure. But I have seen more than 1 VF-40 flapper hit the divorcing plate. It is a known issue and requires grinding down the divorcing plate. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted April 17, 2012 Author Mega Users Share Posted April 17, 2012 ok thanks. ill just take it off and grind it down. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
m sprank Posted April 18, 2012 Share Posted April 18, 2012 Sounds like a plan. Just need to gring enough to clear. Dont have to go nutz hogging it all out. Link to comment Share on other sites More sharing options...
Cloud_a4 Posted April 19, 2012 Share Posted April 19, 2012 I was paranoid about the grinding when I installed my divorced dp but never had any grinding happen. Was it just a certain batch or something? Link to comment Share on other sites More sharing options...
m sprank Posted April 19, 2012 Share Posted April 19, 2012 Welcome to the forum. Grinding does not happen. You perform the grinding. The wastegate flapper can hit the divorcing plate. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted April 19, 2012 Author Mega Users Share Posted April 19, 2012 I was paranoid about the grinding when I installed my divorced dp but never had any grinding happen. Was it just a certain batch or something? I'm almost certain that I do not have the problem with the flapper hitting. I believe the noise is coming from the flow of the exhaust. I'm guessing it has something to do airflow between with the stock UEL, coupled with the Perrin 3" dp, to the stock CBE, that's making this exhaust tone. There are no leaks in the system. The noise is more noticable during decel of course, but still holds a tone under cruise. Wishing someone had a similar setup so I could compare "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
