donyzfr1 Posted April 15, 2012 Share Posted April 15, 2012 I thinking about adding 100 watt h7 bulbs to my 05 LGT. Will they damage my car in any way. They company say that they are compatible. Just want some opinions. Im think about the OEM harness, will it be damaged due to the extra current? And yes I have done the HID lights but I need to keep my DRLs. Link to comment Share on other sites More sharing options...
underground000 Posted April 15, 2012 Share Posted April 15, 2012 the plastic clip can melt, just buy ceramic connectors on eBay (basically extension cords but the bulb end is ceramic - where the heat is) that should be ok 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
allgrownup Posted April 16, 2012 Share Posted April 16, 2012 100w H7's would significantly increase the chance of melting your projector bowls and wiring. if you are going to spend the money on bulbs and ceramic wiring. you will also burn through lights like a fat kid cake running them as your DRL's. The Osram Rallye 65W they produce a great amount of light and a negligible difference in output temps. Link to comment Share on other sites More sharing options...
pillboy Posted April 16, 2012 Share Posted April 16, 2012 My 65 watt Osrams have discolored the plastic housing where the bulb mounts. It is still ugly. Link to comment Share on other sites More sharing options...
donyzfr1 Posted April 16, 2012 Author Share Posted April 16, 2012 Thanks i will just order the 55 watt Link to comment Share on other sites More sharing options...
allgrownup Posted April 16, 2012 Share Posted April 16, 2012 My 65 watt Osrams have discolored the plastic housing where the bulb mounts. how long have you run them, do you use them as DRL also? has it affected light output? I have not had mine in that long. Link to comment Share on other sites More sharing options...
ssbtech Posted April 17, 2012 Share Posted April 17, 2012 I think some discoloration of the plastic housing is normal for any bulb. I too have been running the 65w OSRAMs for several years now. Nice upgrade over stock without any of the risk of 100w bulbs. Link to comment Share on other sites More sharing options...
pillboy Posted April 17, 2012 Share Posted April 17, 2012 how long have you run them, do you use them as DRL also? has it affected light output? I have not had mine in that long. First set went in at about 11,000 miles in 2007 and I am currently at about 43,000 miles. I still have my DRLs activated. What is discolored is the back side of the housing, the part you see when you are changing the bulbs, the reflector side looks fine. It is still ugly. Link to comment Share on other sites More sharing options...
ssbtech Posted April 18, 2012 Share Posted April 18, 2012 Thanks i will just order the 55 watt The 65w OSRAM bulbs are safe and provide better illumination with longer life. My '05 ate up bulbs like no tomorrow, and since using the OSRAMs I've been very happy with their longevity. (I still have DRLs enabled, too) Link to comment Share on other sites More sharing options...
iNVAR Posted April 18, 2012 Share Posted April 18, 2012 First set went in at about 11,000 miles in 2007 and I am currently at about 43,000 miles. I still have my DRLs activated. What is discolored is the back side of the housing, the part you see when you are changing the bulbs, the reflector side looks fine. My drivers side did that. I've been running the Osrams for a few years now... about 3-4. Last week, my wiring melted.... the plastic clip right where it attachs to the H7 base. I had to order a new one from Subaru. It's possible the connection was no good. I've been told by another member here that I trust that if the connection is bad, resistance increases, and temperature goes up. My passenger side works perfectly fine, no discoloration. Might want to double check your connection for corrosion and tight fit. Link to comment Share on other sites More sharing options...
