gergeek Posted April 13, 2012 Share Posted April 13, 2012 Anyone have any tricks installing the Subaru Tribeca front sway Bar on our cars?...I have a 98 LGT...and the only way I think i can install it is by removing the exhaust header which has bolts that dont like to come off. Any hints, links to other installs. This might be a silly question but does anyone know which direction the bar should go on. With the end U shape facing up or down? Bringing my car into a crazy mechanic that is nice enough to help me with this, but figured id ask on here for suggestions. I have Whiteline endlinks (with new nuts, washer and bolts) , 25mm energy suspension bushing and brackets (Brackets need to be bent), and a 25mm FSB from a Tribeca. Thanks Link to comment Share on other sites More sharing options...
iSooby Posted April 14, 2012 Share Posted April 14, 2012 I can't say I've ever heard of anyone putting a Tribeca sway bar on a legacy.. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted April 14, 2012 Share Posted April 14, 2012 Baddog has done it. Just PM him with any questions, or post in the suspension sticky.. You put the bar in the way the stock one came out, and you bolt it onto the outside of the end links Link to comment Share on other sites More sharing options...
Baddog Posted April 14, 2012 Share Posted April 14, 2012 Exactly ^ I removed the Jacking plate as well as the header. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted April 16, 2012 Share Posted April 16, 2012 Link to comment Share on other sites More sharing options...
gergeek Posted April 20, 2012 Author Share Posted April 20, 2012 I got it installed will post pics tonight. Mechanic charged me an arm and a leg for parts, should have just picked them up my self, car rides much stiffer......just need stickier tires now. Link to comment Share on other sites More sharing options...
gergeek Posted April 23, 2012 Author Share Posted April 23, 2012 So the mechanic messed up my O2 sensor when removing the header and the cat..will post pics tonight. Link to comment Share on other sites More sharing options...
gergeek Posted April 23, 2012 Author Share Posted April 23, 2012 Unbolted but clear image of install with Energy Suspension bushings and the basic Whiteline Endlinks Installed Link to comment Share on other sites More sharing options...
