m sprank Posted December 2, 2013 Author Share Posted December 2, 2013 Final day of the Holiday Sale. Link to comment Share on other sites More sharing options...
m sprank Posted December 3, 2013 Author Share Posted December 3, 2013 Tuesday bump. Thanks for all the orders. Link to comment Share on other sites More sharing options...
m sprank Posted December 4, 2013 Author Share Posted December 4, 2013 PM or email for a quote. More tracking sent. Toys for Tots Drive is only 3 days away. Link to comment Share on other sites More sharing options...
m sprank Posted December 6, 2013 Author Share Posted December 6, 2013 Prizes for the Toys for Tots Drive raffle donated so far: Enkei RS+M 17x8, +45m, 5x100, Silver (w/caps) - Infamous Performance Tanabe 4 Point Lower Brace - 08+ WRX/STi - Infamous Performance Gates Racing Timing Belt - 02+ WRX/04+ STi/05-09 LGT/05-09 OBXT - Infamous Performance Grimmspeed License Plate Relo Kit - 02-07 WRX/STi - Infamous Performance Technafit Brake Lines - 02-07 WRX - Infamous Performance Cobb AP V2 Sub-002 - 06-07 WRX/04-07 STi/05-06 LGT/06-06 OBXT/04-06 For XT - Infamous Performance Cobb AP V2 Sub-001 - 02-05 WRX - Infamous Performance Deatschwerks 850cc Top Feed Injectors - Infamous Performance Perrin 25mm Adj Rear Sway Bar w/Mounts - 02-07 WRX - Infamous Performance Perrin 25mm Adj Front Sway Bar - 02-07 WRX - Infamous Performance Perrin 4BAR MAP Sensor - 08+ WRX - Infamous Performance Perrin LW Crank Pulley - 13 BRZ/FR-S - Infamous Performance Goodridge Brake Lines - 08+ WRX/STi - Infamous Performance Stop Tech Front Brake Lines - 05-09 LGT - Infamous Performance AVO Adjustable Front End Links - 04-07 WRX/STi/05-09 LGT - Infamous Performance AVO 0deg Caster Lower Control Arm Bushings - 08+ WRX/05-09 LGT - Infamous Performance Husky Liners Front Floor Mats - 05-08 For/05-06 Baja/93-08 Imp/98-08 Leg/00-08 OB - Turn14 Distribution Snap-On Set, Striking Prybars, Orange, 4 pcs. - Dan Clark Blue Point Ratchet, Cordless, 14.4V - Dan Clark ACVS/Turbo Oil line kit - Outfront Motorsports Top Feed Fuel Rails - Outfront Motorsports Free Track Day (QTY 4) w/driving instruction - Extreme Speed Track Events Swift Springs - 08+ STi/11+ WRX - Fred Beans Parts Kartboy front endlinks - 02+WRX/04+ STi/05-09 LGT - Fred Beans Parts Kartboy rear endlinks - 04-07 STi/05-09 LGT - Fred Beans Parts Link to comment Share on other sites More sharing options...
m sprank Posted December 9, 2013 Author Share Posted December 9, 2013 Thanks to everyone who braved the weather and made it out to our Toy drive! Your donations are greatly appreciated. Special thanks to all our Sponsors: Turn14 Distribution Fred Beans Parts Dan Clark Snap On Tools Delicious Tuning Outfront Motorsports Extreme Speed Track Events Infamous Performance Some pix of the event: http://i105.photobucket.com/albums/m225/godzillong/InfamousToys4Tots120713/1471305_10152032320172156_124844769_n_zps1364b232.jpg http://i105.photobucket.com/albums/m225/godzillong/InfamousToys4Tots120713/966096_10152032902897156_104228258_o_zps0a8e2207.jpg http://i105.photobucket.com/albums/m225/godzillong/InfamousToys4Tots120713/1459134_10152032903582156_631095707_n_zpsc0609d91.jpg Link to comment Share on other sites More sharing options...
m sprank Posted December 10, 2013 Author Share Posted December 10, 2013 http://www.infamousperformance.net/images/store_version1/storelogo/LOGO.jpg We are now offering remote e-tunes from Delicious Tuning! http://www.infamousperformance.net/media/05/a20791e142b59f3439ad41_m.png Tunes available for 99-02 Impreza/Forester, 02-14 WRX, 04-14 STi, 05-12 LGT, 13+ BRZ/FR-S, 05-14 Legacy N/A. Tuning via JEC Reflash, AccessPort or EcuTeK. Delicious Tuning offers remote e-tuning across the entire world, having tuned vehicles in China, Japan, Australia, Philippines, Abu Dubai, Dubai, Saudia Arabia, Lebanon, France, Italy, Sicily, Greece, England, Ireland, Man of Isle, Germany, Norway, Sweden, Switzerland, South Africa, Brazil, Mexico, Canada, Hawaii, Puerto Rico, to name a few. We have been remote tuning since 2002, starting with the Link engine management system and slowly working into the EcuTeK and most recently Cobb. If you are looking for a solution in your part of the world that has no local tuners, no dyno's or just to hard to get anywhere for any such professional services we can offer a solution. Our history speaks for itself and we hope that some more of the information below will help answer any further questions you might have. If not please contact us for additional assistance. The process of E-Tuning or Remote Tuning: 1. We will need to know all the engine performance parts on your vehicle. (Sometimes we suggest changing, adding or even removing parts). 2. Once we have determined and agreed with the modifications you have performed we can then send you a base map to begin tuning. (EcuTeK cable of Cobb AP required) 3. Once you have installed the map into the vehicle ECU we will need to go through the logging process. 4. Once a log has been completed please send us the log, we will review it and send a revised map for you to log again. 5. This process will continue until the car is to a "tuned" state. Logging Parameters for Cobb or EcuTeK - A/F Correction #1 - A/F Learning #1 - A/F Ratio #1 - Calculated Load - Dynamic Advance Multiplier - Engine Speed - Feedback Knock Correction - Fuel Pump Duty - Ignition Timing - Injector Duty - Intake Temp - Manifold Abs Pressure - Mass Airflow Voltage - Throttle Position - Wastegate Duty Max Logging Driving Conditions First log we will need - Log, idle when warm. - Log, cruising around at steady states - Log, partial throttle, into say 5 pounds of boost. Second log we will need (usually after sending a revised map) - Stop there and send logs, if things are good i will then say Third log we will need (usually after the previous maps/logs are running well) - Log, partial throttle, into about 10 pounds of boost - Log, full throttle pulls from 2k-Redline Requirements - EcuTeK or Cobb EcuTeK ProECU Cable Kit - REQUIRED to reflash ECU with EcuTeK maps EcuTeK ProECU License - REQUIRED if ECU has not previously been tuned with EcuTeK (can be purchased with cable kit) Cobb AccessPort V3 through Infamous Performance Cobb AccessPort V2 through Infamous Performance Available via our website here: http://www.infamousperformance.net/servlet/the-3089/Delicious-Tuning-Remote-E-dsh-Tune/Detail Link to comment Share on other sites More sharing options...
m sprank Posted December 11, 2013 Author Share Posted December 11, 2013 http://www.infamousperformance.net/images/store_version1/storelogo/LOGO.jpg We are having a HUGE 2013 Holiday sale. Almost every single product we sell is discounted 10% now until 12/31/13. Use Promo code "2013" at checkout to receive the 10% off. Orders over $299 get free shipping too!!! Link to comment Share on other sites More sharing options...
m sprank Posted December 12, 2013 Author Share Posted December 12, 2013 Use promo code 2013 for 10% off, free shipping on orders over $299 too! Link to comment Share on other sites More sharing options...
m sprank Posted December 14, 2013 Author Share Posted December 14, 2013 Bump for the sale. Thanks for the orders. Use code 2013 to save. Link to comment Share on other sites More sharing options...
m sprank Posted December 16, 2013 Author Share Posted December 16, 2013 Hope you had a great weekend. More orders shipping today. Tracking sent via email. Thanks. Tuning on the dyno again this Friday. EcuTeK just released the 04+ STi Flex Fuel tables!!! Flex Fuel for your STi now available!!! Link to comment Share on other sites More sharing options...
m sprank Posted December 17, 2013 Author Share Posted December 17, 2013 Did I mention Flex Fuel tunes are now available? No more flashing maps at the pump. Link to comment Share on other sites More sharing options...
m sprank Posted December 18, 2013 Author Share Posted December 18, 2013 Wednesday bump. Busy with motors this week. One '03 WRX, one '04 STi and one '13 FR-S all showed up with blown motors this week. No we did not build or tune these motors, Lol. Link to comment Share on other sites More sharing options...
m sprank Posted December 19, 2013 Author Share Posted December 19, 2013 Thursday bump for the 10% off sale. Still time to get delivery by Christmas. Link to comment Share on other sites More sharing options...
m sprank Posted December 21, 2013 Author Share Posted December 21, 2013 4 more shopping days until Christmas. More orders shipping on Monday. Link to comment Share on other sites More sharing options...
m sprank Posted December 22, 2013 Author Share Posted December 22, 2013 3 more shopping days until Christmas. More orders shipping on Monday. Link to comment Share on other sites More sharing options...
m sprank Posted December 23, 2013 Author Share Posted December 23, 2013 2 more shopping days until Christmas. More orders shipping today. Link to comment Share on other sites More sharing options...
m sprank Posted December 24, 2013 Author Share Posted December 24, 2013 Last shopping day before Christmas. Link to comment Share on other sites More sharing options...
m sprank Posted December 25, 2013 Author Share Posted December 25, 2013 http://tweakyourbiz.com/global/files/Merry-Christmas-from-Bloggertone.jpg Link to comment Share on other sites More sharing options...
m sprank Posted December 26, 2013 Author Share Posted December 26, 2013 6 more days to save 10% using promo code 2013. Orders over $299 get free shipping too. Link to comment Share on other sites More sharing options...
m sprank Posted December 27, 2013 Author Share Posted December 27, 2013 5 more days to save 10% using promo code "2013" at checkout. Orders over $299 get free shipping too. Link to comment Share on other sites More sharing options...
m sprank Posted December 28, 2013 Author Share Posted December 28, 2013 Only 4 more days to save 10% using promo code "2013" at checkout. Orders over $299 get free shipping too (to Con US). Thanks for the orders. Lots of tracking sent. Link to comment Share on other sites More sharing options...
m sprank Posted December 29, 2013 Author Share Posted December 29, 2013 Only 3 more days to save 10% off almost everything we sell using promo code "2013" at checkout. Orders over $299 get free shipping too (to Con US). Link to comment Share on other sites More sharing options...
m sprank Posted December 30, 2013 Author Share Posted December 30, 2013 2 days remaining to save 10% off almost everything we sell using promo code "2013" at checkout. Orders over $299 get free shipping too (to Con US). Link to comment Share on other sites More sharing options...
m sprank Posted December 31, 2013 Author Share Posted December 31, 2013 Final day of the sale! Happy New Years! Link to comment Share on other sites More sharing options...
angeltalin Posted December 31, 2013 Share Posted December 31, 2013 Picked up a fx300 for my legacy off the site today thanks for the awesome deal and help you give mike Happy New Year Sent from my XT907 using Tapatalk StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
