82DMC12 Posted April 11, 2012 Share Posted April 11, 2012 Hey all, I have a spare JL 12" in a box with a 250 watt alpine amp. I want to add it to my factory system. I do have the factory sub which I would probably uninstall. What's the quickest way to hook up the trunk sub? Tie into a rear speaker in the door? Use the factory sub wiring? What additional parts would I need? Been a long time since I put any stereo stuff in a car! Andy Link to comment Share on other sites More sharing options...
dsickles Posted April 11, 2012 Share Posted April 11, 2012 youll want to use a line to output convert the speaker signal to a lower level rca output, most will also allow you to adjust levels and frequency. I suggest using the rear speakers if you have navigation, that way the sub will shut off when a navi prompt comes up. Link to comment Share on other sites More sharing options...
82DMC12 Posted April 12, 2012 Author Share Posted April 12, 2012 Cool, do I just wire it up in parallel to a single speaker, like the driver side rear speaker, or do I need to tap into both sides? Link to comment Share on other sites More sharing options...
82DMC12 Posted April 12, 2012 Author Share Posted April 12, 2012 Ok well my amp has speaker level inputs so i ordered an adapter from ebay so i can use it. Does anyone have a write up for running wires from the door speakers to the trunk? How would I use the remote sense lead? Link to comment Share on other sites More sharing options...
