94lgt Posted April 8, 2012 Share Posted April 8, 2012 Ive got a 1994 Legacy Gt non turbo. Its throwing codes 11 & 13 but it starts and runs just fine. Is there anything i could/should do to get the CEL to go off. Or just leave it be. Link to comment Share on other sites More sharing options...
monkeyposeur Posted April 9, 2012 Share Posted April 9, 2012 Code 11 is your crank angle sensor, and code 13 is your cam angle sensor. Both sensors are really easy to replace since they are very accessible. The crank angle sensor is located above the crank pulley, and the cam angle sensor is located behind the driver side cam sprocket. You can find cheap replacements on ebay. Here is a link from surrealimage from bbs central on how to read error codes, and how to reset the ecu: http://www.surrealmirage.com/subaru/engine.html Link to comment Share on other sites More sharing options...
