EvilCamaroSS Posted April 7, 2012 Share Posted April 7, 2012 Hey guys I'm doing my brakes today and I'm just wondering to the brake pad we ar indicators go up or down? Link to comment Share on other sites More sharing options...
shadowsports Posted April 7, 2012 Share Posted April 7, 2012 They should be installed down on the inboard pads. Be sure the indicator doesn't interfere with the return spring clips. They just need to be able to contact the rotor once the pad thickness reaches about 3mm. Don't try to tuck them in under the return spring. Once you get them on, you'll see what I mean. Link to comment Share on other sites More sharing options...
EvilCamaroSS Posted April 8, 2012 Author Share Posted April 8, 2012 They should be installed down on the inboard pads. Be sure the indicator doesn't interfere with the return spring clips. They just need to be able to contact the rotor once the pad thickness reaches about 3mm. Don't try to tuck them in under the return spring. Once you get them on, you'll see what I mean. Thanks, I Posted this from my phone while I was doing the brakes, I ended up having them at the top, only because the rear pads were at the top and you can't reverse those, so I figured the rest should be at the top as well. Link to comment Share on other sites More sharing options...
