mwm5094 Posted April 4, 2012 Share Posted April 4, 2012 So after I installed my RacerX FMIC I decided to come up with something so the cold side pipe wasn't jammed in-between the motor and coolant overflow. Heres what I came up with and it didn't cost me anything due to already having anything but can't imagine this would cost more than $10-$15. I didn't want to pay $140 for the Perrin 1. I Had 2 (one silver and one green) of these bottles at my work. Perrins can measures 3" diameter x 6" tall. This is exactly the same. http://i1110.photobucket.com/albums/h443/mwm5094/6cad3414.jpg 2. I used the dremel to make the cap flush. Drilled 1/4" hole. Used 1/4" fuel line to replace the stock. 2 feet will be plenty, just cut off what you don't need. http://i1110.photobucket.com/albums/h443/mwm5094/09ea759d.jpg 3. Put a self tapping screw in it so the zip-tie couldn't slip. Also put gasket maker on the screw so it doesn't leak. http://i1110.photobucket.com/albums/h443/mwm5094/80489e16.jpg 4. Other mounting pics. As you can see it sits on the pipe nice and has plenty of clearance from the FMIC pipe. http://i1110.photobucket.com/albums/h443/mwm5094/ab826ed9.jpg http://i1110.photobucket.com/albums/h443/mwm5094/fed8c68f.jpg So far so good. No rattles / vibrations / movement. If any issues do arise I will address them and update here. Link to comment Share on other sites More sharing options...
