Input on fluid levels
Hey guys-
I am not a DIY'er, so I had the dealership do a 30k maintenance last weekend. I figured I would check under the hood and see how everything looked. When checking the dip sticks, one thing I thought looked a little odd was the Diff Fluid and Transmission Fluid. I checked them after the car had been in the garage for 3 hours and the dip sticks pulled for 30 minutes so everything would drain and I could get an accurate reading.
Anyway, from what I can tell, these two are slightly high (hopefully it is easy to see on the images). Just wanting to check and make sure I wouldn't run into any issues. Thanks for your suggestions.
Diff
http://i43.tinypic.com/v441ec.jpg
Transmission
http://i41.tinypic.com/1604pc3.jpg
Did you check the trans fluid with the engine running and after shifting through all the gears? If so, its going to read high. Recheck it using the method I just said. The diff fluid is a little overfull but probably is not going to cause a problem with that slight overfill in a diff. An engine or trans would be a different story.
That diff level should be OK but if your shift shaft seal is seeping it may aggrivate the leak. Slightly overfull engine oil is not a big deal, but if it is more than a half quart over, I would adjust I the level.
