gergeek Posted March 27, 2012 Share Posted March 27, 2012 Hey i have been having an issue with my steering wheel. The steering wheel shakes at exactly 60 mph and then goes away above 62 mph. Pretty soon I will be switching over to new summer times. The snows i have on now only have 2,000 miles on them. But does anyone have a clue of what it could be? ......Also posting a build thread soon, now that i have some more time. Checked the tires and they look completely normal and there isn't any uneven wear, this it could just be an amplitude of some frequencies at 60mph. Link to comment Share on other sites More sharing options...
dudeondacouch Posted March 27, 2012 Share Posted March 27, 2012 Tire out of balance, likely a front. You may have thrown a wheel weight. Link to comment Share on other sites More sharing options...
gergeek Posted March 27, 2012 Author Share Posted March 27, 2012 Well switching to summers soon so that's good. I thought if it was an out of balance tire, it would get progressively worse as the speed increases....but mine just goes away above 62mph..and doesn't happen until I reach 60 mph. Link to comment Share on other sites More sharing options...
dudeondacouch Posted March 27, 2012 Share Posted March 27, 2012 Your out-of-balance wheel/tire rotates at different rates, depending on vehicle speed. When this rotational frequency matches the the resonant frequency of your suspension, you get the shake. Link to comment Share on other sites More sharing options...
gergeek Posted March 27, 2012 Author Share Posted March 27, 2012 Sweet thanks for the info Link to comment Share on other sites More sharing options...
silverone Posted March 28, 2012 Share Posted March 28, 2012 [ QUOTE=greek;3817844]Sweet thanks for the info not so fast, Ive seen front wheel drive cars that even with different wheels and tires you cant get rid of a pesky high mph shimmy. I had gm fwd car I gave up trying to fix, just couldn't drive between 70-75 mph. Drove it that way for years! I kept expecting a wheel hub bearing or half shaft to go out but it never did. Link to comment Share on other sites More sharing options...
dudeondacouch Posted March 28, 2012 Share Posted March 28, 2012 While it's entirely possible that the OP has an issue other than wheel/tire balance, the liklihood is very low. Bent wheel, loose control arm, misalignment. All possible, but 95% chance of balance issue. Link to comment Share on other sites More sharing options...
Frank B Posted March 29, 2012 Share Posted March 29, 2012 I can't remember how many cars I've had that shook like that, and everytime, new tires took care of it. It may not be worth it to take it in and pay for a rebalance if you can wait until you need tires. Don't worry about the bearings or axles being damaged by it, they really don't turn as fast as people think. For example, on my 96 Legacy Brighton(which shakes at 70 ) with 185/70-14 tires, the tires rotate at 834 revs per mile. So at 60 the axles and bearings are at 834 rpm, not that fast compared to other parts of the car like engine and tranny. You can rotate the tires to try to help. Generally if you feel it in the steering wheel it's the fronts, if you feel it in your seat, it's the rears. Of course, it wouldn't hurt to check the suspension and other components that hold the wheels on! Good luck. Oh, here's a tire size calculator to see how many revs per mile your tires are turning. It's been a very useful tool for me. http://www.miata.net/garage/tirecalc.html Link to comment Share on other sites More sharing options...
FlyOver Posted June 20, 2012 Share Posted June 20, 2012 My 2007 Forester does exactly the same thing: steering wheel/front wheels shake at 60 mph. New tires, shakes, rotated tires (front to back) reduced but came back just the same. begins at 58, shakes to 62 with 60 being the peak. Its not his tires. Link to comment Share on other sites More sharing options...
jamal Posted June 20, 2012 Share Posted June 20, 2012 Could be a damaged axle. I had a similar problem. Heard a pop pulling out of a driveway, and then from about 50-55 I'd get a nasty shimmy. I pulled it apart for fun and one of the bearings was just not there in the inner cv. Link to comment Share on other sites More sharing options...
Frank B Posted June 20, 2012 Share Posted June 20, 2012 I just took my car in for repairs, not only was it shaking at 70, the inner edge of the tires were becoming very worn. Down to the cords actually. I found a lot of play in the tie rods. So new inner tie rods and boot, new tires all around, and a front end alignment. No more shake at 70. Link to comment Share on other sites More sharing options...
gergeek Posted June 20, 2012 Author Share Posted June 20, 2012 Got my car new tires and balanced that helped a lot, back in March. Glad you were able to fix your problem also. Link to comment Share on other sites More sharing options...
