Blow Posted March 27, 2012 Share Posted March 27, 2012 So last time I logged I had way to many things I was looking at mainly b/c I did not know what I was doing. Now I know a little more and have a different tune. Car seems to be running good but... I am getting code P0171 so bank 1 lean. Things that have changed in the last week are a CNT catted downpipe and a new cobb stage 2 tune. I have had both of these for almost a week and the code did not show up until 3 days after the DP and the tune. Cleared the code then two days later it showed up again. Anyway here is the log. https://docs.google.com/spreadsheet/ccc?key=0Aq02xQKN52HUdFNWY21nZU1DTHpwOVpLWVlHM0VieVE Is this telling me anything is wrong? Well something must be wrong now that I am getting that code and I was not before. Car is a 05 OXT 5 speed with just a downpipe and a stage 2 cobb ots tune. Going to be doing the uppipe this week after I install my new front axles. Going from stock catted UP to cattless STI UP Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 you're logging the wrong stuff, add knock sum and feedback correction and fine learning correction you probably have a vac leak since you're only hitting 15 psi on a stage 2 ots map Link to comment Share on other sites More sharing options...
Blow Posted March 27, 2012 Author Share Posted March 27, 2012 Ya know I was thinking those would be good to look at too. I will log again with those included and look for some vacuum lines that may have come off. Thank you Sir Link to comment Share on other sites More sharing options...
