1astrokeit Posted March 25, 2012 Share Posted March 25, 2012 i picked up these wheels and they were pretty bad shape. the lips needed to be redone, so i figured i would give it a shot. so i started wet sanding with 220,500,1000,1200, and 2000 grit. after that i hit it with buffing wheels. i buffed in this order, tight sewn with tripoli and loose cotton with white rouge. i applied mothers mag and aluminum polish. they look good from far but up close they have fine scratches in them. anyone happen to know how to get them out? should i have buffed white rouge with tight sewn wheel? the first two pictures are the before and the bottom are the finished product http://i1000.photobucket.com/albums/af123/1astrokeit/th_rim1.png http://i1000.photobucket.com/albums/af123/1astrokeit/th_rim2.png http://i1000.photobucket.com/albums/af123/1astrokeit/th_rim3.png http://i1000.photobucket.com/albums/af123/1astrokeit/th_rim4.png Link to comment Share on other sites More sharing options...
No DRFT Posted March 28, 2012 Share Posted March 28, 2012 Looks better than before. I think your mistake was using the 220 grit. I think it's a bit too rough on the surface. Try polishing it a bit more. I have no control over drippie. Link to comment Share on other sites More sharing options...
1astrokeit Posted March 28, 2012 Author Share Posted March 28, 2012 im going to try re wet sanding from 100 grit and up. then polish. Link to comment Share on other sites More sharing options...
