Reckoner Posted March 22, 2012 Share Posted March 22, 2012 I want to do a 98 2.5l GT turbo car I know I need a second 2.5 for a build with sti pistons im wondering if need Sti/Wrx swaybar, Rear diff, Trans, rear sub frame ect. or if the Gt parts with handle 250-325hp Link to comment Share on other sites More sharing options...
michiganSOOB Posted March 22, 2012 Share Posted March 22, 2012 it will handle it but it wont be reliable for long id suggest updating to stronger trans and diffs a jdm 6speed would be hawt Link to comment Share on other sites More sharing options...
Reckoner Posted March 22, 2012 Author Share Posted March 22, 2012 it will handle it but it wont be reliable for long id suggest updating to stronger trans and diffs a jdm 6speed would be hawt Would a 5-Speed AWD Manual 4X4 EJ20 Turbo Subaru WRX Impreza GC8 tranny mount up to a EJ25 Link to comment Share on other sites More sharing options...
jamal Posted March 22, 2012 Share Posted March 22, 2012 there is no difference in gear size/strength between any 90-02 5-speed. in around 03/04 they started putting in slightly wider gears commonly known as the 05+ LGT gearset. Note I said slightly. You do need a turbo front crossmember and swaybar to clear the exhaust manifold and up-pipe. The biggest challenge of doing something like this IS NOT getting the parts to physically fit. Pretty much everything is a bolt in deal. The hard part is actually wiring the car so it actually works. Link to comment Share on other sites More sharing options...
Reckoner Posted March 23, 2012 Author Share Posted March 23, 2012 there is no difference in gear size/strength between any 90-02 5-speed. in around 03/04 they started putting in slightly wider gears commonly known as the 05+ LGT gearset. Note I said slightly. You do need a turbo front crossmember and swaybar to clear the exhaust manifold and up-pipe. The biggest challenge of doing something like this IS NOT getting the parts to physically fit. Pretty much everything is a bolt in deal. The hard part is actually wiring the car so it actually works. Well im gonna use a 2.5GT as a platform for the 2.5T motor so the wiring shouldnt be so bad. it wont be as bad as the wrx neon we just finished up Link to comment Share on other sites More sharing options...
