bakabakablah Posted March 22, 2012 Share Posted March 22, 2012 I have the upper half of an OEM DP for sale. Approx. 16k miles, cats are intact. $60 picked up. Edit: Don't need a silencer anymore. Link to comment Share on other sites More sharing options...
bakabakablah Posted March 28, 2012 Author Share Posted March 28, 2012 Bump. Decided to keep the exhaust for now, adjusted price of the DP. Link to comment Share on other sites More sharing options...
kosugesan Posted April 23, 2012 Share Posted April 23, 2012 Where are you located? Also, will the 07 fit the 05 GT MT? Thanks Link to comment Share on other sites More sharing options...
bakabakablah Posted April 23, 2012 Author Share Posted April 23, 2012 I'm in Cerritos/Fullerton most of the time, with daily trips to Pomona/Diamond Bar. I'm pretty sure all MT downpipes should be the same for 05-09. Link to comment Share on other sites More sharing options...
Kaos22B Posted April 23, 2012 Share Posted April 23, 2012 I'm in Cerritos/Fullerton most of the time, with daily trips to Pomona/Diamond Bar. I'm pretty sure all MT downpipes should be the same for 05-09. The trans bracket on the side is different from 5 speed to 6speed. So if you have a 5 speed DP, it will have to be cut off to fit onto the 6speed, however the 6speed's bracket is shorter so it will fit on a 5 speed model without cutting. Link to comment Share on other sites More sharing options...
kosugesan Posted April 23, 2012 Share Posted April 23, 2012 So the 6spd works on the 5spd, but not vice versa? Will there be fitment issues? Thanks again. Link to comment Share on other sites More sharing options...
bakabakablah Posted April 23, 2012 Author Share Posted April 23, 2012 I'm not entirely sure that's true (I can be wrong, though). But in any case, this DP originally came from a 5mt LGT. I needed the lower half of it to replace mine, and posted up the upper half that I didn't need. Link to comment Share on other sites More sharing options...
Kaos22B Posted April 23, 2012 Share Posted April 23, 2012 So the 6spd works on the 5spd, but not vice versa? Will there be fitment issues? Thanks again. That statement is true if you don't want to cut anything. Note that you won't be able to bolt the top half of the downpipe to the transmission either way. The opposite is true, only if you cut the bracket (which is longer on the 5speed). So the only negative is that you have 1 less bracket supporting the weight of the downpipe. You can see the L shaped bracket in the photo in the original post, its sticking straight up in the middle. Link to comment Share on other sites More sharing options...
bakabakablah Posted April 23, 2012 Author Share Posted April 23, 2012 Seems like you were right Kaos, my apologies. - Specific post showing 5mt downpipes not fitting the 6mt without modification here (whole thread here, and another relevant thread here) However, I would like to reiterate that the upper half of an OEM downpipe I have for sale originally came from 5mt LGT, and would in all likelihood satisfy kosugesan's needs. Link to comment Share on other sites More sharing options...
Kaos22B Posted April 23, 2012 Share Posted April 23, 2012 Seems like you were right Kaos, my apologies. - Specific post showing 5mt downpipes not fitting the 6mt without modification here (whole thread here, and another relevant thread here) However, I would like to reiterate that the upper half of an OEM downpipe I have for sale originally came from 5mt LGT, and would in all likelihood satisfy kosugesan's needs. Yeah it will work fine, I ran a 5speed stock downpipe on my 6speed swapped GT, just cut the bracket, you can shorten and reweld it on to fit if you'd like as well. Link to comment Share on other sites More sharing options...
oside13 Posted April 24, 2012 Share Posted April 24, 2012 Im still getting that silencer out to you sorry for the delay Link to comment Share on other sites More sharing options...
bakabakablah Posted June 11, 2012 Author Share Posted June 11, 2012 Anyone need a cat? Link to comment Share on other sites More sharing options...
