lingling1337 Posted March 22, 2012 Share Posted March 22, 2012 Does anyone know how deep of a speaker I could install in the front doors of an 06 legacy? I have hybrid audio imagines that are specd at 2 3/4", but are probably closer to 3" deep. Link to comment Share on other sites More sharing options...
Burnzy8151 Posted March 23, 2012 Share Posted March 23, 2012 Q: What are the speaker sizes? A: 6.5” all around with a slightly less then 2” depth. Anything more then that will needs spacer rings. The speakers in the front doors have a splitter in the door that splits the lead to the tweeter and the 6.5” in the door. http://www.legacygt.com/forums/showthread.php?t=7154 for a good example of a speaker installation. Link to comment Share on other sites More sharing options...
phenryiv1 Posted March 28, 2012 Share Posted March 28, 2012 I have put 2.5" deep speakers in the doors with just a 3/4" spacer and they had some space left behind them but I can't recall exactly how much. I can do spacers up to 1" in total depth (by stacking 3/4" with an additional 1/4" spacer), but I have not gone beyond that thickness. Additionally, I have made spacers for the Imagines and have not had an issue with window interference. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
utc_pyro Posted March 29, 2012 Share Posted March 29, 2012 I have SB Acoustics (OEM of the ARC Black line) in my car right now, and they fit with a phenryiv1 adapter and an additional 1/4" of diy spacer rings. They are just over 3" deep. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 30, 2012 Author Share Posted March 30, 2012 I have put 2.5" deep speakers in the doors with just a 3/4" spacer and they had some space left behind them but I can't recall exactly how much. I can do spacers up to 1" in total depth (by stacking 3/4" with an additional 1/4" spacer), but I have not gone beyond that thickness. Additionally, I have made spacers for the Imagines and have not had an issue with window interference. Cool man, glad to hear from someone with experience with the Imagines. Did you install them too? If so, did you put the tweets by the door handle or closer to the driver? Or coax? If only that climate control double din unit werent so expensive I could drop all my equipment in Link to comment Share on other sites More sharing options...
phenryiv1 Posted March 30, 2012 Share Posted March 30, 2012 Cool man, glad to hear from someone with experience with the Imagines. Did you install them too? If so, did you put the tweets by the door handle or closer to the driver? Or coax? If only that climate control double din unit werent so expensive I could drop all my equipment in I did not do the install- I only supplied the adapters/spacers. My tweeters in my WRX are in the sail panels. not perfect, but perfectly stealth. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
