Weekend Shooter Posted March 21, 2012 Share Posted March 21, 2012 If my 5th Gen Legacy GT has the ABS Self Test kicking in with the crunchy sound at 20kph, does it mean that the brake fluid in the ABS is being released so that I won't need to have the ABS cycled when I bleed the brakes? It seems nobody cycles the ABS to bleed the fluid. I supposed it's because the fluid does move around each time the car is pulled out of the garage. There's a guy that bleeds, slams on brakes to cycle ABS, and bleeds again. That's probably not needed? Any thoughts welcome! Link to comment Share on other sites More sharing options...
