iNVAR Posted March 22, 2012 Share Posted March 22, 2012 Great! Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 ok but heres what i get now, which do i select??? and i got rid of the subaru folder, i cut and pasted the contents to the rommeadata folder Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 Theres only one that pertains to your car read the list Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 You are 2005-2006 Subaru DBW models FXT/OBXT/LGT/Baja, assuming you do have a 2005 LGT, right? Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 Now if I could only get this guy's shit to work: http://legacygt.com/forums/showthread.php/does-look-learning-view-thanks-182174.html Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 lol, ok i ....i...was just making sure, which would you chose though...lol 05 -06 subaru dbw models xxxxxxxx/lgt/xxx ??? thanks guys, bmx your pic is beyond words great and your caption about the eye thingy...nice! lol Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 it takes a little bit bout 2-3 minutes to read it. nice work guys, thanks again Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 07+ canbus lgt's read much faster but that is normal for you Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 good to know. iNVAR dont think im going to be any help on your other guys issue, ive been reading his too while doing mine, but i got nothing. Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 so am i correct: now that i have my oem rom saved i can load my infamous tune and click test write then click write?? Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 yep. the first write takes the longest, but the subsequent writes should be fairly quick. keep a backup of your stock rom somewhere. Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 Yes, click the save icon after pulling your rom. Once saved go to file - close rom. It takes your rom off the screen. Then click the folder and find infamous' tune then test write then write! Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 i didnt close it i exited out and the reopened ecuflash, then did as you described. looks like it worked, and i already did some test rr logging with the defogger button and that seemed to work. sooooo i guess its off to do the third gear thing. Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 can a guy leave the green connectors passanger side connected when driving and doing the third gear pull??? Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 NO. You MUST unplug it first. Then turn your key so the dashboard lights up, wait 5 seconds (the ECU is rebooting) and THEN start the car. If you don't wait 5 seconds, your engine will just keep cranking for 5 seconds until the ECU reboots so just wait. Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 ok, so when your logging do you have them connected??? Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 No, they are never connected unless you are flashing. Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 How do you know if you got a "clean pull"??? Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 You have a log. Send it to infamous. He's in charge of your tuning. Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 thought id share this with you guys and 2manysubies was right about the IAM being .5 after disconnecting the battery terminals. after running it went back to 1.000 Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Author Share Posted March 22, 2012 will do iNVAR and thanks again for the help. this forum is the reason im deciding to keep this car, after the headaches ive been thru with it. Link to comment Share on other sites More sharing options...
