rens914 Posted March 20, 2012 Share Posted March 20, 2012 hi guys yust drove the car and have seen that: the cruise control light go's on and off (and the cc doesnt work) the engine light is on the right headbeam light doesnt work is there a connection ? have checked all the fluids and the car doesnt drive on limp code. it reacts like normal any help ? rens Link to comment Share on other sites More sharing options...
Nrw Posted March 20, 2012 Share Posted March 20, 2012 Step 1 find out what code your ecu is throwing. Link to comment Share on other sites More sharing options...
frank_ster Posted March 20, 2012 Share Posted March 20, 2012 head light burned , and some sort of engine code is pending. cruse is pourposly disabled if any engine code is pending. witch totally sucks Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
rens914 Posted March 20, 2012 Author Share Posted March 20, 2012 found out that the CC light flashes and CC is out of order when the CEL is on and read something about gas cap. so whent down and fastened the gas cap better, and disabled the battery (to have a reset) will have a look tonight. greetz rens Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 20, 2012 Share Posted March 20, 2012 Your car is trying to tell you something. You might want to consider listening. Link to comment Share on other sites More sharing options...
rens914 Posted March 20, 2012 Author Share Posted March 20, 2012 youre right, and the way to find out what is to erase possibilities. first one is the gas cap. when de CEL comes back in it's not that forgot to say that the car is running on LPG almost all the LPG cars have CEL lights kicking in it seems to be a matter of higher temperature. lamda sonde can't handle that or gives a faulty code. when the light comes back in i'll ask my son to read out the ecu. rens Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted March 20, 2012 Share Posted March 20, 2012 I had a knock sensor go and it wouldnt pull a CEL but would turn the cruise light on... eventually CEL came on telling me it was the knock sensor, but it took me forever to figure out what was doing it.. Pull codes-post results- conversation will get somewhere Link to comment Share on other sites More sharing options...
Hypoid Posted March 20, 2012 Share Posted March 20, 2012 Hope it's not a **** P2096!! Like some other car I won't mention! Link to comment Share on other sites More sharing options...
wai_pang2 Posted March 21, 2012 Share Posted March 21, 2012 sweet, LPG!!! What is the gas mileage and how many gallon tank? Link to comment Share on other sites More sharing options...
rens914 Posted March 21, 2012 Author Share Posted March 21, 2012 sweet, LPG!!! What is the gas mileage and how many gallon tank? 10 liters per 100 km or @#$%^%$#@ 4,2 gallons on the 100 miles it's a 62 liter tank (so 80% filling is about 48 liters) and it's installed in place of the extra tyre rens Link to comment Share on other sites More sharing options...
cybaster Posted March 21, 2012 Share Posted March 21, 2012 Link to comment Share on other sites More sharing options...
frank_ster Posted March 21, 2012 Share Posted March 21, 2012 is it a propor lpg using the fuel injectors ? or a weird thing on the intake tube that is a make shift maf that just kinds of dumps fuel in ? i have seen some pretty weird systems in portugal. i was not suprised that the cars are not allowed in underground garages ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 21, 2012 Share Posted March 21, 2012 youre right, and the way to find out what is BY asking my son to read out the ecu. rens Whats up with the code? Enquiring minds want to know how the car handles LPG. Link to comment Share on other sites More sharing options...
rens914 Posted March 22, 2012 Author Share Posted March 22, 2012 the codes were erhmmm there was something about the airflow meter and something with the catalic converter. my garage has reset the ecu and thinks it has something to do with moving my boat and trailer (3500 kg) the ecu could have reacted on the readings the CEL lighted up the day after the mecanic thinks the ERG could be dirty will clean it next week car runs really great on LPG i fill her up with a smile every time gr rens Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 22, 2012 Share Posted March 22, 2012 You moved a 3500kg boat/trailer with your Legacy? Thats epic! Link to comment Share on other sites More sharing options...
frank_ster Posted March 22, 2012 Share Posted March 22, 2012 ^ that is a lot more common in europe, there is often two horse trailers being pulled by a golf! and there trailers pretty much all have excelent brakes. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
rens914 Posted March 23, 2012 Author Share Posted March 23, 2012 yep powerwise there was no problem what so ever even when i i backed up on the boat ramp (did switch it to petrol and used the manual gear change instead of LPG and automatic gearbox) if there was something to mention than it would be the backside next time i will have to fit load adjusters rens Link to comment Share on other sites More sharing options...
