Ridgeracer Posted July 5, 2005 Share Posted July 5, 2005 Hey all. Anyone get any brake noise every once in a while.? I think the service manual suggests that you clean and grease the pads and rotors every 10K but I forgot. So thats what I did to all four corners. Problem solved. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
PhilT Posted July 5, 2005 Share Posted July 5, 2005 Hey all. Anyone get any brake noise every once in a while.? I think the service manual suggests that you clean and grease the pads and rotors every 10K but I forgot. So thats what I did to all four corners. Problem solved. Might just affect your stopping distance though, 60 - 0 in 5 miles ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 5, 2005 Author Share Posted July 5, 2005 LOLOL....No grease on the rotor or pad face.... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
gt_ltd Posted July 5, 2005 Share Posted July 5, 2005 Hey all. Anyone get any brake noise every once in a while.? I think the service manual suggests that you clean and grease the pads and rotors every 10K but I forgot. So thats what I did to all four corners. Problem solved. which page in the manual? This Space For Rent Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 6, 2005 Author Share Posted July 6, 2005 Check the section on maintenance schedule. Every 15K the brakes should be inspected. I noticed when I took the pads out they had some corrosion on the metal liners and they didn't have any grease between them. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
gt_ltd Posted July 6, 2005 Share Posted July 6, 2005 thanks. This Space For Rent Link to comment Share on other sites More sharing options...
Xenonk Posted July 6, 2005 Share Posted July 6, 2005 Do you need new brake pads? Are you wearing down to the indicators?? Keefe Keefe Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 6, 2005 Author Share Posted July 6, 2005 Naw...brakes are still like new. They just started to make some niose when I would stop. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 6, 2005 Author Share Posted July 6, 2005 Keefe....You know that special grease that goes on the metal liners behind the pads....? Well those were all rusted a little and had no grease on them. Thats where I suspect the noise came from or just brake dust buildup... BTW....I only noticed one wear indicator one of the pad sets.?? Very strange. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
melayout Posted July 6, 2005 Share Posted July 6, 2005 Do some bedding and it should go away till the pad deposits wear off the rotor and you get the noise back. At least that's how I'm coping with it till I get aftermarket pads with better material. I keed I keeed Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 6, 2005 Author Share Posted July 6, 2005 I'll see if it comes back after a week or two... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
TLS Posted July 6, 2005 Share Posted July 6, 2005 We've had brake squeak/squeal for about 5K miles now. Yes, it's only sometimes, but a brand new car shouldn't have squeaky brakes. I guess I'll be doing it myself, as it'll be a full wasted day trip to the dealer for this. Link to comment Share on other sites More sharing options...
BatChips107 Posted July 6, 2005 Share Posted July 6, 2005 i have 7000 miles on the car and already need to reface my rotors and my breaks squeek horribly... also in my opinion, Subaru made a really poor breaking system for the LGT.. too much power and weight for such weak breaks Link to comment Share on other sites More sharing options...
melayout Posted July 6, 2005 Share Posted July 6, 2005 Brakes are not weak. I can stop on a dime with the stock brakes, but the stock tires, RE92s, lock up and ABS kicks. You need to change the stock tires because they are the problem and teh suck, but I've learned their adhesion limits and take that into account. The only problem with the brake system, is the pad material. It unevenly deposits on the rotors under hard driving and causes brake shake(rotor warp). I keed I keeed Link to comment Share on other sites More sharing options...
Xenonk Posted July 6, 2005 Share Posted July 6, 2005 ^ +1 Keefe Keefe Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 6, 2005 Author Share Posted July 6, 2005 Well since we are talking about upgrade brakes now, has anyone tried Cobb Tuning LGT pads? I can't afford the Endless pads Keefe....sorry "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
BatChips107 Posted July 7, 2005 Share Posted July 7, 2005 can anyone recommend some better pads to help stop this problem...? I hear alot about ceramic pads being better than conventional carbonmetallic.. any input? Link to comment Share on other sites More sharing options...
TLS Posted July 7, 2005 Share Posted July 7, 2005 It's not the pad material making the squeak, its the back of the pad vibrating on the caliper. Link to comment Share on other sites More sharing options...
TLS Posted July 7, 2005 Share Posted July 7, 2005 This is all you need. Couple of bucks at your local auto parts store. http://www.permatex.com/images/catalog/special/82017.jpg Link to comment Share on other sites More sharing options...
inthedeck Posted July 7, 2005 Share Posted July 7, 2005 TLS... how much of the stuff do you 'apply' between the backing plate, and the caliper...? Any special techniques? TIA Link to comment Share on other sites More sharing options...
TLS Posted July 7, 2005 Share Posted July 7, 2005 You just smear it all over the back (Metal portion) of the pad with your finger. Especially where the pad contacts the caliper. I use it on EVERY disc brake job I've done. Link to comment Share on other sites More sharing options...
nasiocks Posted July 22, 2005 Share Posted July 22, 2005 Yes I just noticed this for the first time today (12k Miles). I thought that was a little soon for brakes, especially the way I brake (nice and easy). And after chceking them out, the pads look like new. For being such large rotors/capilers (according to the stats) these brakes suck. I will definitely be replacing the tires with something else in the near future. Link to comment Share on other sites More sharing options...
