Metal2You Posted March 18, 2012 Share Posted March 18, 2012 On the front I know the endlinks are supposed to go between the sway bar and the mounting point on the chassis. In the rear I installed mine like the picture shows, where the endlink is on the inside of both the swaybar and the chassis mounting point. I was taking off an old set of aftermarket endlinks from a different company because I didn't have the suspension under load when I did those years ago and the bushings were a bit scrunched. I believe I had the rears installed between the swaybar and the chassis with the old endlinks. Is the way I installed the new Kartboy endlinks in the rear correct? Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 18, 2012 Share Posted March 18, 2012 That's how mine is. http://sphotos.xx.fbcdn.net/hphotos-ash4/248941_10100243459587512_68138246_47954606_5231548_n.jpg Link to comment Share on other sites More sharing options...
jhawk222 Posted March 19, 2012 Share Posted March 19, 2012 You're installation is spot on! Link to comment Share on other sites More sharing options...
