rdp2n Posted March 17, 2012 Share Posted March 17, 2012 OK -- I give up -- I have looked for information on how to fix a leaky power steering reservoir but haven't found much in terms of an actual procedure. The reservoir leaks a pool of fluid on to the top of the engine. I have checked steering under opposedforces.com/parts and the steering pump O ring (part # 34427AA060) looks like a likely candidate for replacement. Do I need any other parts besides this to fix the leak? Do I just empty the reservoir, get the reservoir off the car (how?) and replace the O ring / other parts? Do I need then to bleed the system (what's the procedure for that?) If I have to bleed the system, is it worthwhile getting the steering pump kit and refurbishing the pump while I'm about it? (the owner was not complaining about steering issues) Thanks, Rob Link to comment Share on other sites More sharing options...
SpecBamf41 Posted March 17, 2012 Share Posted March 17, 2012 i was gonna rebuild my pump but idk how it come apart. you cant get to the bolt on the inside of res. BNR18g on 93oct Link to comment Share on other sites More sharing options...
LegacyLou Posted March 18, 2012 Share Posted March 18, 2012 http://www.ebay.com/itm/390397766191?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Or if you dont want to go throw all the work http://www.ebay.com/itm/390397766191?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted March 18, 2012 Share Posted March 18, 2012 Just use a turkey baster or something like that to get the fluid out of the res use a flashlight and look down in the res and u will see a bolt take it off and you can get to the o ring and the is usually what leaks. Link to comment Share on other sites More sharing options...
